Results 1 to 8 of 8
Reload Thread: Can 8 awg power a 750w amp?
    danfortner's Avatar
    danfortner is offline Senior VIP Member
    Mar 2003
    Mystic, CT
    34
    216
    15
    OK,
    Right now I am running a US Acoustics 1000D amplifier off of 4 gauge wire. The amp is supplying a 12" Eclipse Titanium with 750w RMS at 2 ohms. This is a class D monoblock amp. As of now, this is the only thing running off of the my battery, there is a inline fuse 80A about 6 in from the battery and then 2x40A fuses on the amplifier.
    But I am adding an Audiocontrol Epicenter to my setup, so I will be needing to split that power cable to something else. I have distribution and power blocks that accept 4 awg inputs and 8 awg outputs. I just realized that would mean halving the size of the wire going to my amp. The Audiocontol device only takes a 1 amp fuse so it will not be drawing very much power, 8awg will be fine, but I am unsure if my amp will be alright with 8 awg power and grounds.
    So my question is:
    Will that amp require more current than 8awg wires will be able to handle?
    If not, I know my amp can run on 6awg wire, where can I find a distribution block that accepts 4awg or larger and outputs at least 6awg?
    Comon, gimme a hand, remember how anxious you were to install once you got your stuff!
    THANKS
    DECK - stock Acura-Bose Premium Sound w/ 6 CD-Changer
    SPEAKERS - 4 stock Bose & 2 stock 6x9's
    SUB - 12" Eclipse Titanium 9122
    AMP - US Acoustics USX-1000D
    EQ's - AudioControl Epicenter
    BOX - homemaid 1.7 cu. ft ported box @ 35hz (w/ neon & plexi)
    WIRE - 4 gauge w/ distribution and power blocks - KnuKonceptz
    DAMPENING - 50ft of Second Skin Damplifier
    CAR - 99 Acura 3.5 RL - V6 w/ 210hp - all stock
    NEXT - replace anything Bose, add HU, add navi
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    Re: Can 8 awg power a 750w amp?
    knukonceptz.com recently got distros like that.
    phoenix gold were the only ones i found before, @ sounddomain, but knukonceptz do now too, so go w knu, cheaper.
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
    danfortner's Avatar
    Mar 2003
    Mystic, CT
    34
    216
    15
    OK so your saying that 8awg cannot handle the current required to produce 750w. That was pretty much what I was thinking, it just ***** that I have to upgrade my distos and power blocks and buy more wire ect.
    Sep 2003
    St. Louis
    33
    110
    You could run a separate 12-16 awg wire for that epicenter. and then just run the 4 awg to the amp.
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,013
    1 Post(s)
    264 Post(s)
    As long as the 8 ga wire is kept short you're fine.
    4 feet of 8 ga is capable of safely passing MORE current than 12 feet of 4 ga.
    There are several very useful wire calculators on this page.
    crhye250r's Avatar
    crhye250r is offline Installer
    Oct 2002
    Clay, KY
    33
    985
    yes..just run 14 guage wire to the audiocontrol..you will be fine..
    MECP Certified Installer
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    36
    13,103
    21 Post(s)
    mabye even run the 14 ga from the amp to the other device
    danfortner's Avatar
    Mar 2003
    Mystic, CT
    34
    216
    15
    I just got the Audiocontrol Epicenter, and the power, and ground inputs are tiny (well compared to 4 or even 8 awg inputs) so I will be going with something even smaller than 10 awg. This will definately not be drawing very much current, so I don't really have to go all out in the wiring upgrades.
    -thanks
  1. Amp recieving power but not making power?
    By packerfan in forum General Discussion
    Last Post: 11-03-2003, 11:56 PM
  2. What is a High Current Amp?
    By meanman101 in forum Amplifiers
    Last Post: 10-25-2003, 09:02 PM
  3. Computer power supply for car amp
    By lexiphanic in forum Subwoofers
    Last Post: 10-06-2003, 01:19 AM
  4. Which amp to power my CDT HD-62 CF's
    By Rmsanger in forum Amplifiers
    Last Post: 09-14-2003, 09:37 PM
