Results 1 to 2 of 2
Reload Thread: RCA Connection issue
    Dookie's Avatar
    Dookie is offline Junior Member
    Nov 2003
    Las Vegas, NV
    41
    15
    Hey whats up! In my future system set-up I will have 4-channel RCA connection available to my two amps in the system--a Kicker KX600.1 and 600.4.
    I will be using the 600.4 for 4 channel stereo and the 600.1 for mono to the subs. The dilemma I am having is that the 600.4 doesn't have RCA pre-outs, but the 600.1 has 2-channel RCA outs. That being said, could I connect the 600.1 upstream of the RCA signal, then pass it to one side of the 600.4? The thing I'm worried about is that if I only use one set of RCA's going into the mono amp, I will lose bass output when I use the fader on my HU. Is there any way around this?
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Re: RCA Connection issue
    It's OK to parallel RCA's into two amps. Just use a Y cable and hook 'em up.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
  1. 2003 cavalier install help (power issue)
    By valuepac in forum Wiring, Electrical and Installation Help
    Last Post: 10-23-2004, 02:20 PM
  2. Question about DIY RCA cables
    By b0mbrman in forum General Discussion
    Last Post: 05-23-2004, 09:05 PM
  3. Combining RCA outputs?
    By LWW in forum General Discussion
    Last Post: 09-11-2003, 02:34 PM
  4. hu/wiring harness connection
    By -=BD=-gEIGH in forum Wiring, Electrical and Installation Help
    Last Post: 08-14-2003, 07:44 PM
