Results 1 to 4 of 4
Reload Thread: question about what size fuse
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    32
    37,876
    i plan on running 2 1001 bd rockford amps and both say they need 100 amp fuses. i got 2 gauge going to the trunk with a distrobution block with 2 100 amp anl fuses. So i was wondering what size fuse to use under the hood? do i still stick 100 amp? and has anybody ever used circuit breakers? are they better than fuses?
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,013
    1 Post(s)
    264 Post(s)
    Re: question about what size fuse
    You're actually pushing the limits of 2 ga wire, but since we're talking about music (I'm assuming) and not test tones all the time I think you're fine.
    You should use at most a 200A fuse at the battery, if not something a little smaller - 175 maybe. It's not an exact science - a fuse won't blow the second it sees it's rated current. It takes time for the fuse to melt and pop. Generally a fuse can pass double its rated current for a few seconds before it blows. 175A instead of 200A would just give you a little bit higher factor of safety in the case of a short.
    Fuse breakers will work, but they are mechanical and have a lot higher rate of malfunction. Plus, I believe they DO trip at the instant they try to pass their rated current.
    iceteebone's Avatar
    Aug 2003
    Michigan
    32
    37,876
    should i upgrade my wire to 1 guage going to the trunk? I don't know if this is a dumb question or not but could i use 2 fuses under the hood or not? I'm trying to be cautious on what fuse to use cause i already fried an amp before from a power surge.
    80_Cutlass_mn's Avatar
    80_Cutlass_mn is offline What needs to be here?
    Nov 2002
    Anderson,Al
    32
    1,809
    Yea you could use two fuses. To double the fuse rating, take two fuse holders and parallel them. Something like this....
    ----fuseholder----
    -----l l-------------
    ----fuseholder----
    I know this isnt very good but its as good as I could think.
    With this configuration, if both the fuses were 100 amps then the final amperage of the whole thing would be 200 amps. At least I think. But im pretty sure that would be correct.
    Nevermind, it wont work, it keeps scrunching it all together, but just take the two fuseholders and place them in between the ---l l----, where the l's stand for something like t-off's.
    Arctic White 1995 Camaro 3.4L
    Hifonics BX2005D- 12" IA Death Penalty
    Premier prs-x220 - MB Quart DSD213 components
    Pioneer DEH-P7600MP - Scosche 4 Ga. wiring kit
    Aol Instant Messanger: CamaroMN1995
  1. what size inline fuse?
    By phazeone in forum Subwoofers
    Last Post: 10-14-2003, 03:03 AM
  2. dblock and fuse question
    By maniackilla in forum General Discussion
    Last Post: 09-20-2003, 07:29 PM
  3. best size fuse for Avionixx 800.2?
    By tommyk90 in forum Wiring, Electrical and Installation Help
    Last Post: 09-09-2003, 12:13 AM
  4. wire size..... 2 amps
    By er1kkull in forum Wiring, Electrical and Installation Help
    Last Post: 07-20-2003, 02:34 PM
  5. fuse question
    By TIGERFOR2 in forum Wiring, Electrical and Installation Help
    Last Post: 07-16-2003, 10:06 AM
