Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
Reload Thread: Adding second battery
    Bobby322's Avatar
    Bobby322 is offline CarAudio.com Veteran
    Oct 2008
    TX
    3,940
    This is the correct way to wire up another battery right? Is the 2nd fuse necessary? I dont have the ground the second battery again, it will ground out through the other battery?
    CA.com refs: midwestcustoms3 ; dadon ; DBBOOM ; stevexyz ; Twisted_0912 ; on1wheel01 ; vitveet ; basscort2009 (2) ; TeamPSI ; hotboxn ; xbearxlawls (SCAMMER) ; annarbor84 ; trailz516 ; Pioneer~Saturn ; dub22 ; Kern417 ; jbizzle ; wgsj_fortvalley
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,059
    2 Post(s)
    Re: Adding second battery
    Quote Originally Posted by Bobby32 View Post
    2nd fuse is necessary. and i would also fuse the wire from the battery to the amp. i don't like un-fused pos wires. bad things happen to them
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
    Mar 2009
    Dalton, GA
    113
    Dont mean to thread jack but I have a question to.
    Do you need to have the same number of negative runs as you do positive? Ex. If I did 2 runs of Positive do I have to have 2 runs of Negative.
    2003 20th AE VW GTi
    HU: Eclipse AVN62D
    Components:
    Component amp: JBL GTO 75.4II
    Subs: RD Audio Alpha V2 (soon to be rebuilt by PSI)
    Sub amp: AQ3500D
    ___________________
    Bought from:Mike465, Goindef
    Sold to: Tez4life, Soulman07, johnbubby5(SCAMMER)
    Traded with: Basscort2009
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,059
    2 Post(s)
    Quote Originally Posted by Yellow20thAEGti View Post
    depends on how much power you are running. i only have the pos run and neg thru chassis. aka both batteries grounded to chassis so i have no neg run (for now).
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Apr 2009
    dallas tx
    6,962
    1 Post(s)
    u dont have to run the ground to the back. this is the easiest and best way i have found to run my extra batts
    Mar 2009
    Dalton, GA
    113
    This is what I suspected since the negative is a ground. I guess my next question one be is it necessary to have as many grounds as you do positive runs to the second battery then.
    2003 20th AE VW GTi
    HU: Eclipse AVN62D
    Components:
    Sub amp: AQ3500D
    ___________________
    Apr 2009
    dallas tx
    6,962
    1 Post(s)
    u dont need to run another ground. look at my pic. u only need a pos run and just ground the second batt to the chassis
    Mar 2009
    Dalton, GA
    113
    Quote Originally Posted by basscort2009 View Post
    So you are saying no matter how many positive runs I do to the second battery I will be fine with just grounding point for the second battery?
    2003 20th AE VW GTi
    HU: Eclipse AVN62D
    Components:
    Sub amp: AQ3500D
    ___________________
  9. #9
    Apr 2009
    dallas tx
    6,962
    1 Post(s)
    yes just ground the back battery however many times u run a positive from the front, IE 4 runs of pos to the back battery, ground the back battery 4 times
  10. #10
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,059
    2 Post(s)
    it's debatable. it depends on how well your car conducts the electricity. personally, i say if you are 2-3k+watts i would go with a pos and a neg run between the batteries.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  11. #11
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,059
    2 Post(s)
    i dont think that is good advice. it depends on the resistance of the chassis.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
  12. #12
    andrewmoore13's Avatar
    andrewmoore13 is offline CarAudio.com Veteran
    Oct 2007
    Gloucester, MA
    25
    2,191
    i have 2 batts and have had 1 run of each between the batts since day one.
    only problem is if i ground the amps to the rear battery i get huge alt whine... if not it disappears.
    HU: Alpine iVA-w505
    Processor: Alpine PXA-H701
    Front Doors: Shok Comps
    AMP Speakers: Diamond Audio D7104
    AMP Subs: American Bass VFL 150.1 gold
    Subs: 2 Custom Sundown Z12s. Dual 2
    Kicker 1/0 wire (soon to be Shok 1/0)
    Stinger SPV44 and a XS Power 5100
    refs: http://www.caraudio.com/forum/showthread.php?p=5007514#post5007514
  13. #13
    Mar 2009
    Dalton, GA
    113
    Quote Originally Posted by jco1385 View Post
    i dont think that is good advise. it depends on the resistance of the chassis.
    Well how about 2 runs of positive and 1 negative run between batteries and ground the second battery to the chasis.
    2003 20th AE VW GTi
    HU: Eclipse AVN62D
    Components:
    Sub amp: AQ3500D
    ___________________
  14. #14
    Apr 2009
    dallas tx
    6,962
    1 Post(s)
    they say u need a ground wire as big as a neg right??? ok well if u have 4 1/0 wires run back there for pos and only one 1/0 ground then what do u think is gonna happen....
  15. #15
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,059
    2 Post(s)
    same = same
    and yes, you want them to be equal. thats why i wouldnt recommend upgrading to 2 runs pos and still running the neg thru chassis. that creates a bottle-neck. if you want to run one pos run, and ground to the chassis, that is (generally) ok. but more pos runs means you need more ground to complete the circuit. so (IMHO) if you run 2+ pos runs, you should do the same for the ground
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
