Results 1 to 6 of 6
Reload Thread: 10 and a 12 in a 2 chamber box?
    cockeyed00's Avatar
    cockeyed00 is offline Senior VIP Member
    Jan 2003
    Antioch, CA
    272
    How would a 10 and 12 sound in a 2 chamber box? I was planning on fiberglassing behind my back seat and for visual effect using a 10" and a 12". I know there will be 2 different tones, but will it sound okay?
    thanks
    oO
    DaBaller504's Avatar
    DaBaller504 is offline Livin Loud In Da Blazer
    Oct 2002
    Westover, Pa
    32
    998
    Re: 10 and a 12 in a 2 chamber box?
    Usually you try not to mix different subs and sub sizes. Because when you have different subs (including different sizes) subs will tend to cancel out eachother.
    1995 Chevy Silverado, K1500 With 350 Cubic Inches of Raw Power.
    ali's Avatar
    ali
    ali is offline Junior Member
    May 2002
    pakistan
    40
    i have 4channel amplifier and two kenwood 700watts subwoofers and a pair of pioneer 400watts speakers please tell me how i connect it to get perfect performence
    mattj's Avatar
    mattj is offline Resonant Engineering
    Aug 2002
    Wisconsin
    34
    6,293
    you could always put them in a single chamber box and focus all your power on the 10
    (SUMMER)
    2001 Ford Mustang GT Premium
    Mach460
    Alpine CDA-9835
    KnuKonceptz Wiring
    cockeyed00's Avatar
    Jan 2003
    Antioch, CA
    272
    Doesn't a 12 hit harder that a 10 causing no cancellation right because of different tones and hz? If they where sharing a chamber, will they still cancel? What if they are seperated?
    thanks
    oO
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    35
    873
    1. shared chamber... NO
    if you put two different sized subs with different specs ( TS PARAMETERS ) then you will destroy one or both of your subs because it they would react differenty to the air inside the box with and when one reacts differently then it's like playing a speaker while pushing down on the cone.. you don't do it.
    2. separated chamber... STILL NO.. Well i wouldn't reccomend it.
    Yes the 12 would probably be louder to some extent but they still create sound waves and when sound wave clash they cancel each other out. which would create all sorts of dips and crappy sounds to your spl curve.
    3. your best bet to select either the 12 or the 10 and put it in the box. but if you do the 10 and 12 together it will be like playing your door speakers like subs and running your subs at the same time ( sounds REALLY crappy ). And with the cancellation yes you WILL get cancellation if you run the two together.
