Results 1 to 10 of 10
Reload Thread: 2nd battery installation AND alternator rewire HELP please
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    OK, i ordered a 200 amp alternator from www.mean-green.com it is a direct bolt-on replacement for my stock alternator. I'm also ordering today 25ft. 1/0 awg red welding cable and 10ft. 1/0 black welding cable. I'll be installing my new alternator myself, and want to re-wire with 1/0 red wire...any tips? Basically i just need to run pos. from my starting battery to the alt in 1/0 and use 1/0 black to ground the starting battery correct? Any help would be greatly appreciated.
    AND i'm picking up an optima yellow top this week. I'll be putting that in the back to run my off of it! Now, what all do i need...? an isolator/regulator? How do i go about installing this second battery? Run pos. from the batt. to the alt...and ground it in the rear? and do i need anything else other than the isolator? thanx soo much guys, and if u know any cheap places for any other equipment i need to install this (isolator, etc.) LMK...thanx, peace
    NG
    http://crunktimes.com/ct/
    nG - BSEE
    avistar23's Avatar
    avistar23 is offline www.SoundhertZ.com <---
    Dec 2001
    Nassau Bahamas
    29
    2,723
    Re: 2nd battery installation AND alternator rewire HELP please
    Ive never done that kind of thing before but this is what i would do, ron 0 gauge to the trunk, then have that go the second battery, install your isolator under the hood, ground the second batt to the fraim, and call it a day..... as far as the charging system to the altenator ive never done that and as you know im kinda out of car audio right now so i cant help you off the top of my head
    -Mike
    C6ANU
    Eclipse H/U
    Profile j 600.4 bridged to 2 chanells
    Adire Koda 6.1
    Profile ca1200
    Kove Audio Armegedon 12
    AudioControl Matrix
    Soon to come:
    Audio control 24xs
    Audio control EQL
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    werd, i'm confused bout EXACTLY what i need to buy to get this battery in and run right! like...battery terminals....i can get some wit 0/1 input and 2 4awg output....then i don't really need a distro block right? i could just run an inline fuse to each 4awg? and what size anl for an avionixx1200.2....like 100amp of 150amp...hopefully i'll get some help later tonight! thanx tho, just wanna get this **** straight b4 i order all the components to install it...hopefully be doing it and get doen next week.
    NG
    nG - BSEE
    ParkRat's Avatar
    ParkRat is offline Senior VIP Member
    Sep 2003
    Dallas, TX
    203
    Have you thought about buying a high ouput alternator with dual outputs? This would eliminate the isolator.
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    Quote Originally Posted by ParkRat
    well, my two options are either from mean-green.com or from dominick....i guess i'll check to see if either can do it.
    NG
    nG - BSEE
    ParkRat's Avatar
    Sep 2003
    Dallas, TX
    203
    If you got 2 new optima yellow batteries at once.. you could probably run the two batteries in parallel. To do that the batteries would need to be identical and the same age! Just a thought. Then you wouldn't have to worry about the isolator or regulator. I'm sure somebody with a little more knowledge could chime in.
    n0ftInc's Avatar
    n0ftInc is offline Spoilers Up. Kula Style.
    May 2003
    A Foolish Pleasure In MI..
    711
    What's the difference between an Isolator and a Regulator..?
    What about this..?
    http://cgi.ebay.com/ws/eBayISAPI.dll...category=14932
    '93 Corrado SLC
    Alpine .. SI .. Adire .. Orion .. Optima .. KnuKonceptz
    da12b's Avatar
    da12b is offline Member
    Jun 2003
    Maui, Hawaii
    107
    Icon31 Re: 2nd battery installation AND alternator rewire HELP please
    To my knowlege, an isolator is used to seprate the 2 batteries from being discharged at the same time and yet charge the 2 batteries at the same time.
    A regulator is used with the alternator. It regulates the voltage to the battery(ies).
    Hope this helps you out.
    Aloha
    Ride: 1998 Honda Accord EX Coupe
    HU: Alpine DVA-9681
    Epicenter (in dash)
    Aphex Processer by Kove Audio
    Capacitor: 1 Frad Rockford Fosgate (monitor top)
    Amp: MTX 405 (5-ch.)
    Front: Boston Acoustics Pro60
    Rear: Boston Acoustics SX95
    Sub: 1 (one) Eclipse SW8122DVC (12 in. sub)
    Added the "BIG 3"
    Load Boss Alternator (180 Amps)
    One HC1400 Kinetik Battery (using as main battery)
  9. #9
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    I am currently running a 180a alt with 2 die-hard golds. I have run 2 bats ever since i can remember. I have never used an isolator. I want to the power of both bats for the system. As for a deep cycle bat., I don't think (and have also heard) it's not a good idea with a ho alt. The purpose of a deep cycle is to cahrge and discharge slowly. An ho alt wil be trying to charge it quickly.
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
  10. #10
    Trixter's Avatar
    Apr 2002
    40
    2,609
    29
    2 Post(s)
    Here's the thread I was looking for...http://forums.caraudio.com/vb/showthread.php?t=40704
    scroll down to where Golemon talkes about what he would do...actually the entire thread is pretty good
    2006 Jeep Liberty
    *Vb = vol. in cu"
