Results 1 to 6 of 6
Reload Thread: How did you guys install your cold cathode lights?
    Silver5656's Avatar
    Silver5656 is offline Junior Member
    Sep 2003
    Berkeley
    14
    since the ccl's run at 12v's u should just be able to plug them in, rite?.....where do u guys draw ure power from?.....im gonna be runing 2 12's in a custom built box and 1 amp and wanted to include 2 ccl's inside the box.....how would i do this?....where would i mount the switch?....
    http://www.svc.com/svcompucycle/sutwocckitwi.html
    i would use something like that.....anybody have pics?....
    Q45guy's Avatar
    Q45guy is offline Member
    Jun 2002
    Portland, OR.
    43
    141
    Re: How did you guys install your cold cathode lights?
    First of all, get rid of everything from the supplied switch on up to the molex connector (the funny 4-hole connector) and use only the red and black wires that come out of the inverter. This is mearly to clean things up and keep things simple. If you have a power distribution block that supplies your amp with power, then use a lead off of that as your +12v into a switch and to the red wire comming out of the CCFL's inverter. Simple attach the black wire to any ground other than what grounding spot your amp uses. If you ground the inverter too close to where the amp is grounded it will introduce unwanted noise into your stereo. From there its all purdy dang basic. I'd probubly put the switch for the CCFL somewhere near where your box is so that you can just flip it on when you open your trunk or hatch. I have lots of neon lighting in my car and have 6 switches dedicated to different areas of lighting. I'm gonna be changing the switching network soon as it will all be computer controlled.
    Q45guy
    [email protected]
    1991 Infiniti Q45
    Silver5656's Avatar
    Sep 2003
    Berkeley
    14
    um what if i dont use a power dist block?
    Silver5656's Avatar
    Sep 2003
    Berkeley
    14
    also whats the diff between a power distribution block and a regular fuse distribution block/box?
    lombardo's Avatar
    lombardo is offline bass massage
    May 2003
    Rochester, MN
    30
    510
    Friend and I ripped apart his cigarette lighter and used those.
    2000 black Audi A6 2.8
    stock components
    RE HC15"
    tsunami 1100d (kills kids)
    building a 4^3cuft tuned to mid 30's
    some nasty sauce mixed in there.
    AIM - fincorny82 2000
    E-mail - [email protected]
    ridge's Avatar
    ridge is offline ...
    Aug 2003
    Minneapolis, MN
    30
    95
    Quote Originally Posted by lombardo
    yep just took the positive and negative wires from the cigarette lighter and took off the dc adapter on the end of the cathode. Wired those to a switch and boom =).
  1. im new. how to install 4-CH amp?
    By Forty-Ouncer in forum Wiring, Electrical and Installation Help
    Last Post: 06-28-2004, 09:35 AM
