Results 1 to 9 of 9
Reload Thread: 2002 Trailblazer headunit install problems.
    Gearstix's Avatar
    Gearstix is offline CarAudio.com Elite
    Apr 2008
    Alberta, Canada
    25
    818
    My buddy installed a head unit in a 2002 Trailblazer, and is having some problems.
    Here's what he says.
    i have the wiring harness from walmart, for an '02 trail blazer. Hooked everything us as it should be. The CD played gets power, but will not come on. The reset light does flash, but resetting it does not do anything. i know for a fact the CD player is good.
    The stock radio can be plugged in and will work perfectly, but i cannot get anything out of the aftermarket
    Should he get a 'pac module' or similar?
    Quote Originally Posted by stuckinok View Post
    Mach 5 is the **** and dont let the low price fool you. I hated Canada until I used Mach 5 products.
    AlterEgo99's Avatar
    AlterEgo99 is offline Streaming consciousness
    May 2009
    Domie Homie
    12,536
    437 Post(s)
    Re: 2002 Trailblazer headunit install problems.
    Sounds like it may have something to do with the harness...is he using the OEM harness or did he get a harness that will allow the addition of an aftermarket radio? I have a Silverado ('08) and you need either a harness from Axxes and one from PAC (for the steering wheel controls) or, after going that route and calling PAC about a question, I discovered that they have a harness that will handle both the HU and the steering wheel. Of course, your buddies is an '02 so it may not be that complicated.
    Gearstix's Avatar
    Apr 2008
    Alberta, Canada
    25
    818
    I'm not sure, he said he bought a stereo harness for it from wal-mart.
    BigJoker's Avatar
    BigJoker is offline Team D.O.A V.P.
    Nov 2006
    Chicago,IL
    33
    2,094
    27 Post(s)
    Quote Originally Posted by Gearstix View Post
    i think my friend had the same problem in his 04 Envoy. i think the harness was no good. so we just ran new wires.
    refs---gl0ck,unbonyr,xxxpower,sundownz,C5,psych0ticnemes1 ,RydHy3845,DrumProdigy83,Mlstrass,j3bus2k3,chaarli eee,khail19,tapout,sleepyjr,CRXBMPN,skeptikal,head bussaboi,blove1991,jbizzle,DJ,Jonny101abc,rival904 ,popwarhomie
    neutral---djman37,team h&k,sxpimpin
    do not deal with Belunt or hotcarl.
    Worlddre's Avatar
    Worlddre is offline Big Darkie
    Sep 2004
    Charlotte, NC
    33
    18,014
    1 Post(s)
    49 Post(s)
    that harness does not have acc behind the radio so he can purchase the interface harness or run a new acc to the orange wire in the ignition harness
    "humility in the face of overwhelming genius will obviously amount to hypocrisy"
    itsbmw's Avatar
    itsbmw is offline Real Talk
    Aug 2008
    Michigan
    24
    1,120
    tap a fuse that only gets power when the key is turned to the on/start position. That's what I did. I also only used the 7 dollar harness from metra. I used it in my 01 alero and my current 08 grand prix.. I just dont have chimes and my cars didnt have onstar anyway so no big deal. EDIT you want to connect this wire to the red acc wire on the headunit's harness
    Refs:
    Sold to: iDrum182
    Bought From:99grandprixGt(x2), 919motoring, mazzasec, metsfan89
    x1le's Avatar
    x1le is offline I'm certified.
    Jul 2008
    Mass
    29
    1,758
    Quote Originally Posted by Worlddre View Post
    this. I always fuse the wire, too, just to be on the safe side.
    I INSTALL STUFF.
    mecp advanced.
    i do it all.
    Gearstix's Avatar
    Apr 2008
    Alberta, Canada
    25
    818
    you can post on there that i figured it out. I have to use an "ad a circit" from autozone off of a fuse the was on with the key as the acc power.
    Thanks guys.
  9. #9
    dropped_tb's Avatar
    dropped_tb is offline Caviteño_Loco
    Apr 2009
    Miami
    136
    buy a "gmrc-01"
    you need this interface to keep the factory functions (door chimes, etc...)
    Team CACO
    DROPPED_TB FEEDBACK THREAD
    REFS: haunther, crash9201, RollinGTO, JBLCAMRY, Goindef154, btdickey99, Ronin, chornet44, comp2007, djarmy2004, goodstuff, Derrick824, TeamPSI, Worstenemy453, Ridnclean, KyleBechtold, vfrrider, iamsonic, chornet44, headlesskoopa
