Results 1 to 7 of 7
Reload Thread: Subwoofers Popping any answers
    Jonathan112's Avatar
    Jonathan112 is offline Junior Member
    Sep 2003
    Surprise, Az
    My subwoofers are popping and makeing vibration noises when they start to hit hard DOES ANYBODY KNOW WHAT TO DO
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Re: Subwoofers Popping any answers
    yeah, turn it down.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    bass maniak's Avatar
    bass maniak is offline Team Poundin Sound
    Aug 2002
    Faust, Alberta ( CANADA )
    30
    3,182
    113
    :hilarious lol now that i found funny!!
    Chuch AKA Tha Mad Scientist
    Team Poundin Sound
    Joker Kustoms
    Boost Junkie Motor Sports
    Street Poetry Productions
    Wreaking Havoc Records
    maniackilla's Avatar
    maniackilla is offline cout<<"c++";
    Jul 2003
    McKenzie, TN
    804
    what kind of popping? like a staticy pop? check wiring, woulnt want the wiring to be knocking loose when it hit causing small sparkage. also make sure your spider isnt tearing form the cone or it will bottom out easily and may even have a crappy vibrating noise at low volume
    jsharpe's Avatar
    jsharpe is offline Junior Member
    Nov 2003
    pa
    your woofers are exurding too much the only way i found to fix this problem is either have your woofers tight against a back seat or if you can have the woofers hit against a heavy foam
    Spddracer's Avatar
    Spddracer is offline Sounds Goooooood
    Mar 2002
    Ohio
    50
    1,345
    15
    A lillte more info would help . What are you running ? Subs , Amp , what ohm are they at , What type of box , Is it sealed well , Things to check . Leaks in your box , Gain on your amp , Impendence load . Sounds liek your amp is probably clipping because it is turned up to far or the subs are not selaed well in the box
    1990 300ZX Stage IV Twin Turbo
    Pioneer Premier P940MP
    CDT HD 6.5" Comps
    JL 300/4 Active
    (2) PG Ti10d
    Directed 1100d
    "WORK HARD.....
    PEOPLE ON WELFARE DEPEND ON YOU"
    myowngod316's Avatar
    myowngod316 is offline Member
    Oct 2003
    Enumclaw, Wa
    32
    40
    check your RCA jacks in your amp sometimes thoes can be messed up and that will cause popping.
  1. rfp 4410 subwoofers
    By mel in forum Subwoofers
    Last Post: 09-10-2003, 12:54 AM
  2. popping noise
    By orionorion in forum Subwoofers
    Last Post: 08-07-2003, 12:39 PM
  3. Help with 15" Subwoofers
    By Cbear in forum Subwoofers
    Last Post: 07-27-2003, 04:37 PM
  4. Car Audio Subwoofers used in PA
    By chriscam in forum Subwoofers
    Last Post: 07-25-2003, 09:58 AM
