Results 1 to 4 of 4
Reload Thread: Dual Battery Setup Recommendations
    WiCKeD 5.9L's Avatar
    WiCKeD 5.9L is offline Senior VIP Member
    May 2005
    San Clemente, CA
    186
    My Jeep has been chewing through batteries like a rabid dog since I added the aftermarket setup. It just wasted another battery and left me temporarily stranded.
    This is what I am running currently:
    -150A Alternator
    -600w amp
    -200w sub
    -200w PC
    -140w pump
    -10000w gremlins
    Alternator checks out and is holding voltage steady in drive. It is not a huge amount of load, so I think the parasitic drain of everything else is what is killing things.
    What size/kind of batteries would you recommend running? I am not looking to spend a bundle. Also, any advice to help chase down the gremlins?
    Jeep Grand Cherokee 1998 5.9L
    Speakers: Rainbow Audio CS465.25G Germaniums
    Amp: Rockford Fosgate Power T600-2
    Sub: Infinity Basslink
    Sound: Carputer w/7" LCD + stock HU for radio
    References: 6spdcoupe, james33440, pilyin | eBay: sleepeeg3 | Heatware: WiCKeD001
    SicAudio's Avatar
    SicAudio is offline did you fart dude?
    Apr 2009
    melting HO alts...
    42
    6,211
    Re: Dual Battery Setup Recommendations
    check your wiring for all the aftermarket equipment, make sure your amps are off when the key is off. if it didnt do it b4 it was installed then something new ( remote line is the most likely bet ) is constantly drawing current. it sounds to me like you have the amp remote lead constantly powered on.
    until you find the problem a new battery wont help at all.
    do you know how to check for a parasitic draw?
    remove the negative battery cable and set your dmm to 10 amp setting and connect it between the neg cable and the neg terminal on the battery. anything higher than .5 amps is way too much. start pulling fuses til the draw drops below .2 amps. that will tell you what circuit it is. and you can go from there to find it exactly.
    Quote Originally Posted by slammedincouch View Post
    Sic rolled me in front of my mom earlier...
    Quote Originally Posted by misfit138 View Post
    How did you manage to pack that much stupid into such a small amount of words?
    Quote Originally Posted by Magnus View Post
    I got rick rolled by SicAudio lulz
    I just got rick rolled by SicAudio again lulz.
    Quote Originally Posted by chickaboom View Post
    awww.... dude! I can't believe you were the first! to rick roll me! I am a noob!
    sold to: Johnny Law.Lulz/Worstenemy453,Pumkinman, j1b1e1, DexterMoped, miyagi gboo559,CSU87,nate2587, MichaelLane, SmLLySack. MR_Imperial, Herrrerra, ltr450racer690, 05fronty bought from: TripleB45, bigwheel15, (kroid77 but never recieved..)
    helping noobs daily PM me
    May 2005
    San Clemente, CA
    186
    My amps have indicators lights for power status and they do go off, but I have done many other electrical mods that could be causing problems.
    Quote Originally Posted by SicAudio View Post
    Thanks for your advice! So it looks like 12.5v / 5.5 Ohms is bad...
    wesl56's Avatar
    wesl56 is offline el sietes!
    Jun 2006
    NoFl
    2,399
    Quote Originally Posted by WiCKeD 5.9L View Post
    what are you talking about here?
