Results 1 to 4 of 4
Reload Thread: amp shuts off
    KARLEON's Avatar
    KARLEON is offline Livin' Legend
    Mar 2002
    Chattanooga, TN
    32
    1,993
    13
    amp shuts off
    Today my amp played for a while then it went into protection mode. I was wondering is it an electrical problem or is my amp seeing an ohm load that its not capable of putting out? My amp did get pretty hot quickly and the gain is not all the way neither is the volume on the head unit. It hits hard when its on, but after 10min or so it just shuts off. Im at school so i really cant go check things out right now. But as many as replies as possible would be appreciated, so i can go right to the problem
    ULTIMATE SOUNDS & PERFORMANCE Presents TWO DUDES SPL SHOOTOUT - 1st Place Champion
    REFERENCES: Bigbassman, Rangerman, Deserheat, Bavarian, Req, Vosschs, George, Mountaineer Man, NGSM13, Kingpin_jeffie, Harrison, Dustin19, Iceteebone, Electrodynamic, Memphis4L, RaiN, Mikemareen, Omietrice, Suleman36, Jmanpc, Kickerlivinloud, ibanender, massiveaudiocw, phoenix88, polecat, j3bus2k3
    kingpin_jeffie's Avatar
    kingpin_jeffie is offline i need a vacation...
    Mar 2002
    Erie, PA
    1,259
    Re: amp shuts off
    Well how do you have it wired and with what subs?
    Eclipse 8445|Alpine Type X 137r|Diamond D5 300.2/1200.1|ID 10v.3|
    Refs: KARLEON, sephiroth619, SiX, Showrides, angrytrucker78, davidfre21, Relax, Slammed
    He who laughs last is usually the slowest...
    Infinity1230w's Avatar
    Infinity1230w is offline reppin the STL
    Sep 2003
    Missouri
    32
    33
    Re: amp shuts off
    It could be getting over heated or it could be a bad ground. make shur nuthings shorted out if its not one of those the you have a problem with your amp
    maniackilla's Avatar
    maniackilla is offline cout<<"c++";
    Jul 2003
    McKenzie, TN
    804
    Re: amp shuts off
    yea, make sure your amp isnt getting too hot and shutting off. my friend got his concept 800 and we had to break it in and played it @ 1ohm around town maxing out for about 45 mins. had it under the seat for the time being until we mounted it. we could smell the fresh coat of coating getting toasty
    also check the ground, ive seen this be the problem so many times. also, if the prob is heat dont be afraid it cant handle the load, get 2 fans and even them out over the amp. will cost ya about 1 dollar per fan and some spare wood/metal to make a small bracket
  1. Eclipse (or any 4 channel amp) Wiring/Setup Help
    By downsider in forum Amplifiers
    Last Post: 11-16-2003, 08:25 AM
  2. amp for 2 he2 dvc 4ohms ? what amp ?
    By El_dorado in forum Amplifiers
    Last Post: 09-21-2003, 06:30 PM
  3. need help choosing an amp fast for my CDT 61a
    By mdd99 in forum Amplifiers
    Last Post: 09-18-2003, 07:44 PM
  4. Is stock 140 amp alt enough?
    By 60_cent in forum Wiring, Electrical and Installation Help
    Last Post: 09-15-2003, 04:50 PM
  5. Can I wire a MTX Thunder6000 12" To my amp ?
    By Warrior in forum Wiring, Electrical and Installation Help
    Last Post: 09-11-2003, 12:22 AM
