Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Reload Thread: fuse holder melted
    Deuce's Avatar
    Deuce is offline Member
    Jun 2003
    Dover, AR
    83
    fuse holder melted
    my plastic inline fuse holder melted last night and fell apart. Can someone tell me why this happened and if i should just get a new one or if there is something wrong.
    98 Ford Explorer
    ALpine CDA-9815
    Alpine SPR-136A 5.25 comps
    Kenwood KFC-5708C 5X7s
    Alpine MRP-F240
    Fi Q 12 in 2.35^3 ported to 33hz
    Memphis [email protected] ohm
    j_po4071's Avatar
    j_po4071 is offline Junior Member
    Aug 2003
    Where I live
    13
    Re: fuse holder melted
    the fuse holder melted becuz it was mounted or touching something hot, u see heat (like from an engine) gets really hot sometimes and can melt plastic or such things. yes u should get a new one, not sure where u can get just a fuse holder but it shouldnt be more than a few bucks.
    LBX2G's Avatar
    LBX2G is offline R.I.P Camofluage
    Jun 2002
    Warner Robins
    33
    2,713
    yes get a new fuse holder. The reason it melted is because there is to much power going throught the fuse. which means the fuse is to big. u can an new one from about any car audio store.
    FREE Terrelll"peanut" Grayer!!!!!!!!!!!!!!!!!!!!!!!!!!
    adam71's Avatar
    adam71 is offline P9 = Ultimate SQ
    Jul 2003
    Michigan
    5,795
    Quote Originally Posted by Deuce
    So where is this fuse holder located at in the engine compartment or what ?
    Adam
    Source Unit: Pioneer P9 combo
    Tweeters: CDT DRT-25 Silk
    Mids: CDT ES-5 (5.25")
    Midbass: CDT M6 (6.5")
    Subs: Pioneer TS-W12PRS
    Mid & Tweet amp: Pioneer PRS-X340
    Midbass Amp: Pioneer PRS-X720
    Sub Amp: Pioneer PRS-X720
    adam71's Avatar
    Jul 2003
    Michigan
    5,795
    Quote Originally Posted by LBX2G
    Excuse me but if the power was so much that it made the fuse holder melt then it would have burnt the insulation right off the copper wire and possibly burned the car to the ground. If this fuseholder was not in the engine compartment then there could be a real problem that needs to be fixed. You may have copper exposed and touching metal and shorting out your system.
    Adam
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    Plastic inline fuseholders use a spring to push the contacts against the fuse. If the spring broke, or if you had tension on the wires, the contacts could have been making weak connection and result in high resistance. That'll make heat.
    I never use those things for more than 10 amps.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    LBX2G's Avatar
    Jun 2002
    Warner Robins
    33
    2,713
    my brother had 4 aguge power and gound wire. I was lightining audio and he had an 80 fuse in it. B/c he kept blowin fuses and he was goin down the highway and the music quit. He looked under the hood and his fuse holder mellted to the. like i said the fuse is too big.
    - holla
    adam71's Avatar
    Jul 2003
    Michigan
    5,795
    - holla
    Ok, but I was assuming if this wasn't an underhood fuseholder.
    Adam
  9. #9
    jbl_marshall21's Avatar
    jbl_marshall21 is offline important person
    Oct 2002
    nebraska
    2,494
    1 Post(s)
    i'm guessing that the fuseholder is touching something hot under the hood. too much power is kinda a question. how much power r u running and what r the fuse ratings on ur amp?
    Alpine CDA-9886
    RUX-C701
    PXA-H701
    JL xr-650csi
    JL vr-650cxi
    2 8" W7
    JL HD750/1
    JL HD600/4
    2007 Chevy Trailblazer
  10. #10
    defiance's Avatar
    defiance is offline Member
    Aug 2003
    Little Rock, AR
    40
    129
    If there was too much power, then something is severely wrong. The fuse holder should be capable of sustaining itself under load at it's largest capacity fuse. If it was above that capacity, the fuse should have blown.
    My guess, near something hot. In *both* cases.
  11. #11
    adam71's Avatar
    Jul 2003
    Michigan
    5,795
    Quote Originally Posted by defiance
    Exactly what I was thinking......
  12. #12
    s1imjim's Avatar
    s1imjim is offline Junior Member
    Dec 2010
    new jersey
    Icon14 Re: fuse holder melted
    Quote Originally Posted by defiance View Post
    the wire can still heat up due to an overload, the fuse can handle it but the holder is prob a piece of sh, get a good one there worth it or the problems gonna keep happening. good luck!
  13. #13
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes......
    Aug 2006
    Piney Hills of Louisiana
    36,639
    23 Post(s)
    1499 Post(s)
    Whats a fuse
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
  14. #14
    Haunz's Avatar
    Haunz is offline Packing 4/0
    May 2007
    inside a sine wave
    1,886
    26 Post(s)
    The fail in this thread is strong...
    Except for this answer:
    Quote Originally Posted by maylar View Post
    It was caused by either a bad connection at or inside the fuse holder.. a bad connection means an area of high resistance, and that will generate heat.. enough heat to melt the thing...
    Anyone who tells you different doesn't have clue what that are talking about.. that is unless you had it sitting on top of you exhaust manifold..
  15. #15
    Aug 2006
    36,639
    23 Post(s)
    1499 Post(s)
    Quote Originally Posted by Haunz View Post
    The fail in thread is strong...
    more like full of lulz
  1. best size fuse for Avionixx 800.2?
    By tommyk90 in forum Wiring, Electrical and Installation Help
    Last Post: 09-09-2003, 12:13 AM
  2. el cheapo fuse holder
    By kingpin_jeffie in forum Wiring, Electrical and Installation Help
    Last Post: 07-28-2003, 01:25 PM
  3. ANL fuse problem
    Last Post: 07-17-2003, 12:55 PM
  4. fuse question
    By TIGERFOR2 in forum Wiring, Electrical and Installation Help
    Last Post: 07-16-2003, 10:06 AM
  5. Using Power from fuse box
    By tehon3299 in forum General Discussion
    Last Post: 07-11-2003, 05:59 PM
