Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Reload Thread: QUICK voltage drop with little power!! WTF!?!?! HELP PLEASE
    snb778's Avatar
    snb778 is offline blaugh!!!!
    Oct 2004
    ex. Los Angeles, CA
    34
    8,022
    I've got an H.O. alt + optima under hood, Plus Deka G31 in back. I'm runnin only my 4ch. amp right now, and when I turn the volume up to about 30%... my voltage drops right away for some reason!!!
    ***I just had this same system in my car about 2 weeks ago.. ripped it out, and now putting it back in
    This is all with the car on, radio on easy listening level THIS IS WITH OUT MY SUB AMP!!
    Under hood voltage car on: 14.15. I started car, took - off, car stayed on
    Deka voltage: 14.08
    Amp Voltage: 14.04-05
    I will turn the radio up about 2-3 volume, and the voltage drops, and the amp (alpine) will cut out and read (CUR)
    Both main fuses appear to be good...
    Both my grounds are solid... one bolted under hood, one bolted to seatbelt bolt?????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????
    You tell me. only thing I can think of is
    A. Fuse behind the radio is ALMOST blown???
    Refs: Projectpat, XylerB, decipha, blados, protonman, Wlmrs, Nucleareskimo, gl0ck, mobeious, JBizzle (picked up box) mlstrass (box design) Mazzasec (bought 18" RD Alpha from him) SKMFKR: Traded subs Wrenchguy: Sold 18" Q to him. psychoacoustics: bought some bullet horn tweets from him Shinju: bought some 0awg wire from him. Sold a box and 18" HDC318 to chitown_impala. Bought my 2 custom 15's from 99Vic on steave meade forum. NJTStang11- picked up 18" SSX and box from him krispy cream SCAMMED ME $200!!!
    2 Pistol Shrimps in a 4.0 cu^ft box tuned to 32 hz for the WIN !!
    "You can't compare, don't stare, cause I got the ultimate Mary Jane"
    snb778's Avatar
    Oct 2004
    ex. Los Angeles, CA
    34
    8,022
    Re: QUICK voltage drop with little power!! WTF!?!?! HELP PLEASE
    is there any way to test a fuse on both ends to see if the proper amount of current is passing though?? while the fuse is still hooked up
    snb778's Avatar
    Oct 2004
    ex. Los Angeles, CA
    34
    8,022
    ttt??
    tommyk90's Avatar
    tommyk90 is offline THE WHOLE THING!!!
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    How low is the voltage dipping?
    Team Kicker (R.I.P.)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
    2008 Bassrace 130-139.9 Regional and National Champion
    2006, 2007, 2009, 2010, 2012 and 2013 MECA Champion (S1, SR1, DB1, S2, S3, S4, S5)
    One DD 9510 powered by two Sundown SAZ-2500's
    Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
    Kicker wiring throughout.
    snb778's Avatar
    Oct 2004
    ex. Los Angeles, CA
    34
    8,022
    it was going down to 13.5, then it would cut out
    BUT I GOT IT!!!... for whatever reason.. I disconnected one of the tweeters, and switched the polarity, and now it works fine!!!.. I wonder if there was a tiny strand of wire touching the "other" terminal or somethin...???
    snb778's Avatar
    Oct 2004
    ex. Los Angeles, CA
    34
    8,022
    BIGG ISSUE...
    Im waiting for someone to help me out here though PM, but here's what the new issue is
    I've been having some voltage issues, and i've about given up here...
    Apparently for the last few months, my voltage has been dropping down to about 12.5 on the big notes, and I didnt even know this because my amp with the V. indicator light is in the trunk, and I just re-located it to the back seat....Light's don't dim up to i'd say 90% volume. then i get a LITTLE dimming
    I have 180A alt, Big 2 done (no block to GND yet..someone cut it)
    Bluetop under hood
    DekaG31 in back,
    just re-grinded all GNDS, all are/were good,
    tried pulling speakers to see if there was a short or something, didnt change
    Voltage rests at 14.2 car on..
    Batts hold 12.9 car off
    Tried disconnecting the - terminal on batt. to check alt, car stays on
    so im down to the conclusion this ALT. is a piece of ****...
    ANY---other ideas would be GREAT!!
    snb778's Avatar
    Oct 2004
    ex. Los Angeles, CA
    34
    8,022
    ttt... could really use some help here
    cj407's Avatar
    cj407 is offline Banned
    Jun 2008
    Orlando, FL
    2,780
    if you have h/o alt why is your car on no amps on voltage only 14.08...shouldnt it be 14.4....sounds to me like alt is shot....TIME FOR NEW ALT
  9. #9
    bball09124's Avatar
    bball09124 is offline CarAudio.com Veteran
    Jan 2007
    psl, fl
    2,404
    9 Post(s)
    Quote Originally Posted by cj407 View Post
    OMG, your alternator is only charging to 14.1V and not 14.4V, you need a new one!!!!!!!
    bought from: cbrrocketrdr, bk12321, galacticmonkey, jnoel, aaronmiiller, revrider1, QtrHorse, brchd, Calikid, IA2, miker, dontknowanythin, Towncar, woofercooker, speedyg76, cd6551
    traded with: lorilee8284, Boominator
    sold to:ravens9322, Blinkdogo2, dbubble, Fusion_FREAK, oneill584, jrgreene1968
  10. #10
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    31
    21,086
    2 Post(s)
    457 Post(s)
    wow....just wow.
    2,500+ designs since March 2011
  11. #11
    cj407's Avatar
    Jun 2008
    Orlando, FL
    2,780
    so then bball what could be his problem since he's having such a voltage drop with only a 4 channel operating?
  12. #12
    cj407's Avatar
    Jun 2008
    Orlando, FL
    2,780
    **** my lil honda crx stock alt keeps both my batteries at 13 full tilt...14.3 with car on and no amps on...thats out of a 60 amp max alt...so tell me how his 180 amp isnt keeping up with only 2 batteries...??? someone can answer that one?
  13. #13
    bball09124's Avatar
    Jan 2007
    psl, fl
    2,404
    9 Post(s)
    If his amps are still grounded to the seat belt bolt it may be a horrible ground. Even if he sanded it down well, he may need to ground to the frame or to the front battery. That's the only thing I can think of.
  14. #14
    bball09124's Avatar
    Jan 2007
    psl, fl
    2,404
    9 Post(s)
    Some (crappy) HO alts do not charge at all at idle, only after you get the RPMs up a little bit, so that could be the problem as well.
  15. #15
    WOT's Avatar
    WOT
    WOT is offline Banned
    Nov 2007
    Toronto,CANADA
    3,667
    My vote goes to seatbelt ground, car body/frame work best
