Results 1 to 3 of 3
Reload Thread: Can I wire a MTX Thunder6000 12" To my amp ?
    Warrior's Avatar
    Warrior is offline Member
    Apr 2003
    WI
    35
    54
    Hey guys, im going to get rid of my 2 tens and i got a real nice Q-Logic 12" subwoofer enclosure. Its a sealed enclosure and I was just wondering if i will be able to hitch this sub up to my amplifier as I currently have my 2 10" dual 4ohm voice coil subs hitched together for a 4ohm load x 1.
    MTX Thunder6000 12"
    Subwoofer Size : 12 Inch
    Dual Voice Coil : No
    Impedance (Ohms) : 4
    Peak Power Handling (watts) : 500
    Frequency Response (Hz) : 29Hz - 150Hz
    Sensitivity (dB) : 87
    Woofer Cone Material : Injection-Molded Polypropylene
    Woofer Surround Material : NBR Rubber
    Voice Coil Design : 4-Layer, Apical Voice Coil Formers
    Basket Material : Steel
    xMax - Maximum Excursion (millimeters) : 9.4
    QTS : .66
    Fs - Free Air Resonance (Hz) : 29.7
    Recommended Amp Wattage Range : 20 - 250 Watts
    Mounting Depth (inches) : 5.1
    Vas (liters) : 77.2
    My amp
    Continuous Power (20Hz-20kHz, 0.04% THD)
    2 ch: (4 Ohm) 100Wx2
    2 ch: (2 Ohm) 200Wx2
    1 ch: (4 Ohm) 400Wx1
    Maximum Power (EIAJ)
    2 ch: (4 Ohm) 250Wx2
    1 ch: (4 Ohm) 750Wx1
    Frequency Response: 10Hz - 50kHz (0,-1dB)
    Total Harmonic Distortion: 105dB (IHF-A Weighted, at 1kHz)
    Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
    Features:
    Bridgeable 1/2/3 Channel Capability
    PWM Regulated MOSFET Power Supply
    2 Ohm (4 Ohm mono) Optimized MOSFET Output Section
    Balanced Isolator Input Circuit
    Oversized Gold-Plated Screw-Type Power/Ground Terminals
    Gold-Plated Screw-Type Speaker Terminals
    Gold-Plated RCA Inputs
    Gold-Plated RCA Outputs (Full Range)
    Hi-Volt Input Level Control (400mV-6.5V)
    Variable Crossover: 50-120Hz, -12dB/oct. (LPF/HPF)
    Variable Bass Boost (40-120Hz, 0 to +18dB)
    Subsonic Filter (15Hz, -18dB/Oct.)
    Im going to buy this sub at Circuit city mainly because its on sale right now for only $83 and it sounded better than my 2 10s. I believe this sub is a SVC. And its 4ohms...but I could of swore the guy said that it was a Dual 2ohm subwoofer. Either way, I could hitch it up right?
    For a 1 SVC sub, I just hitch the + and - on the sub to the + and - on the amp right? It's a 2 channel amp that has the left and right channel, and it also has the option of putting it bridged, put 1 + from left and 1 - from the right channel.
    What is the best way to hitch this sub up?
    BTW - The amp I have seems to put our a real world average of 600+ watts RMS, atleast thats what almost ever birth sheet says and tests on it. So would it be worth it to spend an extra $50 and get the Thunder8000 12" ?
    '97 Avenger
    K&N Filter
    Avenger Decals
    Tinted Windows
    Sony CA400 HU (50x4watts)
    Sony Xplod 5 1/4s (140watts ea.)
    Jensen 6x9s (180watts ea.)
    2 Pioneer Premier 10" Subs (800watts ea.)
    1 Pioneer Premier PRS-X720 Amp 400watt x 1 @ 4ohms (under-rated)
    n0ftInc's Avatar
    n0ftInc is offline Spoilers Up. Kula Style.
    May 2003
    A Foolish Pleasure In MI..
    711
    Re: Can I wire a MTX Thunder6000 12" To my amp ?
    Is that what your talking about..?
    '93 Corrado SLC
    Alpine .. SI .. Adire .. Orion .. Optima .. KnuKonceptz
    Warrior's Avatar
    Apr 2003
    WI
    35
    54
    Yeah, sorry i didnt reply but Yeah i got it hitched up. I feel like a total retard.... a 4ohm SVC sub is so easy to hitch up . Ugh i feel like a tard, + to + and - to -, geez how easy could it be. LOL I was use to DVC subs, doh.
    Sub pounds hard though, its handling twice as much as its rated it.
    '97 Avenger
    K&N Filter
    Avenger Decals
    Tinted Windows
  1. illumination wire or dimmer wire?
    By -=BD=-gEIGH in forum Wiring, Electrical and Installation Help
    Last Post: 09-15-2003, 12:25 AM
  2. what amp should i get for 2 12" WO
    By tbirdsony in forum Amplifiers
    Last Post: 09-09-2003, 12:17 AM
