Results 1 to 14 of 14
Reload Thread: Adding resistor
    HNaga's Avatar
    HNaga is offline Member
    Oct 2008
    Cairo
    115
    Adding resistor
    I have front speakers 2ohm , I want to add 4ohm tweeters
    the installer man told me that I have 3 choices ,
    wiring them serial
    adding 2ohm resistors to the speakers then wiring them parallel.
    replacing both with a component speakers.
    what do you recommend? I want to keep the sound quality.
    Alpine CDA-9887 with Imprint
    Alpine SPX-17PRO
    Infinity Reference 9613i
    Alpine PDX-5
    Infinity Kappa 120.3se
    93dakota's Avatar
    93dakota is offline CarAudio.com Elite
    Oct 2008
    Ohio U
    660
    Re: Adding resistor
    well the last one sounds like the best option to me if you are going to do it. you really don't need tweeters if you already have 3 way components. the first option is probably doable but 6 ohms will lose you a lot of power and the second option i would never do. I would not throw a resister in line of a speaker though with out it you would be running 1.33 ohms on your amp which i don't think it is stable at. if you must do this i would just get another tweeter and wire the two in parallel then wire the speaker in with them in series and you would end up with 4 ohms.
    Co-Founder OBS
    1993 Dodge Dakota LE 3.9L v6
    1 Fi BTL 18" in Custom wall enclosure
    Alpine CDA-9886
    Hifonics Goliath XXV
    Hifonics Zxi6410
    Mechman Street Beater 250amp Alt
    Powermaster D3100
    8 runs Knukoncepts 1/0 power/ground
    Ferendon's Avatar
    Ferendon is offline Proabbly drukn
    Jul 2007
    Fort Worth, TX
    950
    Re: Adding resistor
    Get components. Done.
    HNaga's Avatar
    Oct 2008
    Cairo
    115
    Re: Adding resistor
    adding another tweeter seems good option till I decide which comp to get
    what do you recommend for $200 range comp with Alpine CDA-9887?
    Alpine SPX-17PRO
    Alpine PDX-5
    Proximity's Avatar
    Proximity is offline CarAudio.com Veteran
    Apr 2008
    Detroit
    28
    2,274
    60 Post(s)
    Re: Adding resistor
    Can you actually run a resistor inline with the speaker wire?
    93dakota's Avatar
    Oct 2008
    Ohio U
    660
    Re: Adding resistor
    Quote Originally Posted by Proximity View Post
    I am sure u could. It would be a waste of poer and not sure how it would sound.
    P.S. Love the sig.... GO WINGS!!!
    Co-Founder OBS
    Alpine CDA-9886
    Hifonics Zxi6410
    Powermaster D3100
    lilmaniac2's Avatar
    lilmaniac2 is offline Ask Me about SI Mag V4!
    Jan 2006
    Somewhere, Else
    30
    15,930
    Re: Adding resistor
    adding a resistor is not the solution, they will heat up and eventually burn out.
    Gebrochen's Avatar
    Gebrochen is offline Eternal Noob
    Nov 2006
    Austin, TX
    45
    91
    Re: Adding resistor
    If you put a 2ohm resistor in series with a 2ohm speaker running at 40W, the speaker will get approximately 20W and the resistor would disipate the other 20 as heat. So, you would need a resistor rated a good bit higher than 20W. This isn't a good solution.
    Moved my car stuff to home:
    4 pair Diamond Audio s600s
    2 Fi BL 18's
    8 10" Sundown SD-1s
    Peavey CS4000
    Behringer EP2500
    dbx DriveRack PA
    RX1602 mixer
    ... yeah yeah... starter stuff
    http://www.myspace.com/cobaltkarma
  9. #9
    smoka's Avatar
    smoka is offline Drink beer save water
    Jan 2009
    Chicago
    664
    10 Post(s)
    Re: Adding resistor
    Quote Originally Posted by HNaga View Post
    If you are going to power the comp set from your HU then probably get a low power set like this:
    http://www.onlinecarstereo.com/CarAu...roductID=17541
    Otherwise you should get a amp if you want to run a good set of comps. There are many to choose from in that $200 range. I've heard these are good:
    http://www.audioque.com/aq/AQG-6_5_comp.htm
  10. #10
    Haunz's Avatar
    Haunz is offline Packing 4/0
    May 2007
    inside a sine wave
    1,886
    26 Post(s)
    Re: Adding resistor
    your installer man sounds like an idiot.
    you will need some kind of crossover for the tweeter.. even if it's just a simple capacitor in series... and if you want to be able to adjust the level of the tweeter to the mid you will need what is called an L-pad. Check out partsexpress.
  11. #11
    Cameron_B's Avatar
    Cameron_B is offline Single Cab Loud
    Jun 2008
    NC
    1,403
    Re: Adding resistor
    Yes, the resister would dissapate half the load, it would make the amp work harder and lose efficiency for no gain in output.
    Past scores-
    144.1
    2x re SE + aq2200 2.8 SEALED in 1995 Camaro
    141.0
    Custom PSI 10" 5.25 depth ported aq2200 1994 ford ranger
    139.9
    RE SR 10" on ED 9.2x 1994 ford ranger ported
  12. #12
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    Re: Adding resistor
    What are you using to power them? For the crossover?
    nG
    http://crunktimes.com/ct/
    nG - BSEE
  13. #13
    Ferendon's Avatar
    Jul 2007
    Fort Worth, TX
    950
    Re: Adding resistor
    Very nice deck-power comps.
    http://www.onlinecarstereo.com/CarAu...roductID=19139
    Feck that.
    The D-series are pretty cheap right now.
    http://www.onlinecarstereo.com/CarAu...roductID=19145
    I have these on my car on deck power, (until tomorrow), and they're pretty solid. I like them better than the $650 Focal 165KFs I sell at work.
    2006 Mercury Milan Premier - White on Cocoa/Caramel Leather
    DEH-P8600MP, TS-D720Cs, TS-SW2501D4 @ 2, PRS-D4200F/1200M. JL 0/1, Stinger SHI RCAs.
  14. #14
    ultimate157's Avatar
    ultimate157 is offline Engineering Student
    Mar 2006
    Worcester, ma
    7,249
    Re: Adding resistor
    Wire up a tweeter with a mid range?
    Good way to toast a tweeter as soon as you play a song.
    2003 Volkswagen Jetta GLI VR6
    Source: Pioneer 880 PRS *Active
    Tweeters: Soon to be Hat Imagine
    Midrange: Soon to be Hat Imagine
    Sub: 15" SSA Icon
    Box: 2.5^3 Sealed
    Amp: Soundstream Tarantula 2kW
    Feedback: http://www.caraudio.com/forum/showthread.php?t=278169
