Results 1 to 5 of 5
Reload Thread: What size speaker wire to sub?
    Unregistered's Avatar
    Unregistered Guest
    What size speaker wire should I use? I went to Car Toys to get wire but ended up not being enough. I have a dual voice coil sub so there are two sets of wire going to t the sub. When I went back to get more wire a different guy gave me a different size wire. I'm guessing that having only one size of speaker wire would be best so when I go back should I get the bigger or smaller size? Is the S.Q. or SPL effected by size of wire? Thanks.
    natem33's Avatar
    natem33 is offline Senior VIP Member
    Jan 2002
    St.Paul, MN
    415
    Your SPL could be affected with too small speaker wire as well as SQ. Depending on the size of your amp and how far the amp is away from the subs I would use 16 guage if a smaller amp and 10 guage wire for bigger amps. Post what your amp is and I'll tell you a better estimate.
    Unregistered Guest
    It is a JBL 300.1 and the Sub is a 12 inch Infinity Kappa Perfect
    mstrblk's Avatar
    mstrblk is offline Junior Member
    Dec 2001
    bay area
    17
    i think 12g or 10g would be fine, for the amount of power you are using
    eclipse 5303r
    JBL 1200.1 - crossfire 75.2
    Audiobahn 12's - 5.25 components
    optima yellow - LA 2f cap
    nateo101's Avatar
    nateo101 is offline Junior Member
    Mar 2002
    Virginia
    29
    just remember one thing, the bigger the wire the easier it will be for the sound to pass through. A litle trick use both strands of the speaker wire on one of the post. Then take another piece of speaker wire and do it on the other side. try and free it up as much as possible
  1. What size speaker wire
    By GMOORE in forum Wiring, Electrical and Installation Help
    Last Post: 04-22-2008, 05:03 AM
  2. what size speaker wire to use?
    By Bagged96Chevy in forum General Discussion
    Last Post: 01-31-2008, 01:50 AM
  3. 800 watts what size speaker wire?
    By hondarider in forum General Discussion
    Last Post: 08-25-2006, 11:12 PM
  4. What size speaker wire to sub?
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 03-18-2006, 09:04 AM
  5. What Size Speaker Wire for Mids/Highs
    By james33440 in forum Subwoofers
    Last Post: 02-15-2003, 03:47 PM
