Results 1 to 12 of 12
Reload Thread: Help! Wiring 2 Sundown SAZ-3000s to 2 subs.
    AcidikBass20's Avatar
    AcidikBass20 is offline Bass Addict
    Nov 2008
    South Bend, IN
    411
    Subs are wired together at 2 ohms. I have 2 sundowns running, 1 amp for each. The subs are both seeing 2 ohms and putting out 1600 to each sub. Which output terminal do I put the speaker wire in. Left or right. It says for 1 sub its right, 2 its left, but the amps are not strapped. Help?!?!
    Head - JVC KW-AVX810J, Delphi XpressRC
    Front - Infinity Reference 6x9, 6.5, 5.5
    Sub - 2 Earthquake DBXi-12 (new coming)
    Amps - 2 Sundown SAZ-3000s, Kenwood KAC-4802
    Acc - 4 Batcap 2000, DC AD250SP alt, 4 runs of Knu 1/0 Kolossus Flecks wire, Stinger fuses and ends
    lostdaytomorrow's Avatar
    lostdaytomorrow is offline CarAudio.com Elite
    Oct 2006
    Loc
    1,574
    Re: Help! Wiring 2 Sundown SAZ-3000s to 2 subs.
    right
    References: Vitveet x2, massiveaudiocw, n00b, darren700, Beerdrnkr, brchd, Mr. C, Raamaudio, h8ter, cman9012, Millertime1028, Teamsubgopoof, ABSOLUTEAUDIO, DB_DRAG_SPL, ls2poweredgoat, RyanM923, Worstenemy453, Connersdad19, pickup1, wgsj_fortvalley, ellocojorge
    Lakota's Avatar
    Lakota is offline Doesn't Know $hit
    Feb 2005
    Louisville, KY
    25
    6,232
    Lets start this over because I'm lost.
    What coil configuration do you have? Once you give me that I can tell you how to wire it.
    Ben Hemp
    1992 GMC Sonoma Ext Cab NEW BUILD
    2008 MECA S1 KY State Champion, 151.0 dB
    2008 MECA S1 WorldChampion, 151.8 dB
    2010 MECA scores: 150.9 dB S2, 151.6 dB S3
    Refs: smd4life, Subst4nce, wccoug21, dacheatham, thegreatestpenn, jshak07
    Nov 2008
    South Bend, IN
    411
    Not Strapped! Each running 1 sub individually!
    each running 2 ohm, 1600w, to an Earthquake DBXi-12d.
    hrtbrk1's Avatar
    hrtbrk1 is offline 1ManWreckinCrew
    May 2008
    Boomer Sooner, OK
    5,757
    u need to explain ure stuff better...im lost as well
    If you ever dealt with me in the past...please post how our transation went here...-->http://www.caraudio.com/forum/showthread.php?p=5274098<--...i greatly appreciate your support
    NeedDirections's Avatar
    NeedDirections is offline alligator toilet seats
    Jan 2007
    Tampa, Florida
    929
    each sub should be wired in series to the amp.
    2002 Volvo S40T
    Pioneer 780
    PG RSD 6.5
    Kicker 300.2
    Treo SSX 12"
    RD 1750.1
    SPL-C115
    Refs: Pimpedout97x, TreyE, Columbus, 95VolvoSx, oxsign, Pioneerpimp (x2), Bones22, PlushDJ, Reson8, JPD2621, rmdl51, Rollerdj, LS2poweredGoat, Orangecounty1, Iamamp3pimp,Woodels420, SQL4Life ...etc.
    Quote Originally Posted by vforvengance
    Forget all that. Iam a bass head the louder the better, the more windsheilds and sunroofs I blast out my car the happier i will be. I hope I lose my hearing to bass, instead of something crappy like IDK jets engines running at wk or whatever. Is preference dude. Some people like it. Imma do myself a favor and bang as loud as I can....
    captaincheesey's Avatar
    captaincheesey is offline Change is Inevitable
    Sep 2006
    Evansville, IN
    2,152
    I think he is asking which terminals on the amp to put the wires in. He has them wired correctly at the sub, but since there are two +s and -s on the amp it is confusing him.
    2002 Grand Prix GT
    Eclipse 7200 (Dead Head + Copper Plated Chassis + Time Alignment)
    HAT Clarus 5 1/4 mids
    Stock Tweets
    Highs Amp: Fultron 6 channel
    Subs: 12" DC Lvl4XL (x2)
    Sub Amp: Hifonics 2006D (temp)
    Nov 2008
    South Bend, IN
    411
    Quote Originally Posted by captaincheesey View Post
    Excactly! Thank you! So are they done right?
    Also, I am gettin a nice whine from the amps while its running. the lower the music and quieter the whine. I think its the amps because I turn the car off and the whine still goes until the automatic shut off kicks on and all the amps turn off. ideas?
  9. #9
    Nov 2008
    South Bend, IN
    411
    Both grounds are running up to the front battery where it is grounded. Is that bad?
  10. #10
    groundpound4200's Avatar
    groundpound4200 is offline Da fuq did I just read?
    Nov 2007
    Mankato, MN
    27
    5,260
    4 Post(s)
    seems a bit excessive
    2007 Honda Pilot 2008 Nissan Maxima
    2 RD D9s strapped @ 1 ohm Sundown SAZ-1500D V.3
    2 Sundown Nightshade V.2s 2 10" Atomic APX
    Sundown SAX-125.2 x 2 Sundown SAX-100.4
    Sundown NeoPro 6.5"s, JL ZR Tweets Sundown NeoPros
    RIP Taylor aka NewAgeKing, you are missed!
  11. #11
    Lakota's Avatar
    Feb 2005
    Louisville, KY
    25
    6,232
    The +'s and -'s are internally bridged...
    This is a mono amp, it doesn't matter which set of terminal you use because they are connected together within the amp.
    Ben Hemp
  12. #12
    GMCJimmyslt2000's Avatar
    GMCJimmyslt2000 is offline ll Faded ll
    Feb 2007
    South Bend, IN
    1,558
    hey if u got some questions or need a hand some time give me a call
    Refs:
    Bought From- Spy, 18inchjeepin, BJ The Man, Jeeper07,
    Pjvoc, lil_italy773, NJTStang11
    Equipment:
    HU- Pioneer 4800
    Speakers- Stock Bose
    Sub Amp- Hifonics Brutus 1100@2ohm
    Sub- 15" Fi SSD w/ Copper Coils
    Box- 3cubes Tuned at 33hz
