Results 1 to 8 of 8
Reload Thread: 4 speakers on a 2 channel amp
    fooch's Avatar
    fooch is offline Member
    May 2008
    Fort Myers, FL
    92
    1 Post(s)
    Ok so I have a Cadence TXA-3002 and Image Dynamics CTX57(75 rms) and Image Dynamics CTX65CS(100 rms).
    I'm going to wire the speakers to a 2 ohm load, how much power will each speaker be getting if the amp is rated at 2 Ohm RMS Power: 2 x 300 Watts? Will the speakers be over powered?
    Also I have this wiring kit http://www.knukonceptz.com/productDe...prodID=KFX-AK4 is this fine?
    The thing is I have to put the components in the back because the depth is too big for the front doors. So is it really better to just power the front speakers off the amp and wire the rear directly to the HU?
    IDSkoT's Avatar
    IDSkoT is offline Resonating Reticular
    Jan 2008
    Miami, Florida
    6,274
    Re: 4 speakers on a 2 channel amp
    I wouldn't.
    But that's me. I<3SQ.
    Lower resistances give out a higher distortion level. Higher = Better for quality.
    Now designing / building boxes.
    (Only building sealed and aero port boxes.)
    PM me.
    Feedback Thread
    Refs: MSW Danny, atsaubrey (great seller), ampjunkielikeme, wgsj_fortvalley, tEh koRnDog, bad @SS chevy, Nismos14 (who is the man. )
    goingdef's Avatar
    goingdef is offline CarAudio.com Veteran
    Jan 2008
    Norfolk VA
    37
    2,834
    1 Post(s)
    864 Post(s)
    i run a p200.2 on my front and rears all left to the left channel all the right to the right channel for a total ohm load of 4ohms on the amp each speaker is good fr 60wrms so I put out about 130wrms at a 2ohm load per channel so each speaker is getting about 5wrms more than it should but it's fine. In your case each speaker will want another 25wrms but should still sound good and you will not be able to drive distortion up high enough on that high of an ohm load to hear a difference good luck
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Quote Originally Posted by IDSkoT View Post
    I<3SQ.
    You're an idiot.
    qkassidyw's Avatar
    qkassidyw is offline MECP Master Certified
    Aug 2008
    Seattle
    443
    Quote Originally Posted by goingdef View Post
    Wow...
    The only period was in the model number of your amp.
    As to the OP; your amp doesnt seem like it will be able to power both sets adequetly. Run the fronts off of the 2-Channel and leave the rears hooked up to the deck. You will get much better sound this way because rears are for SUCKAS! (well, not suckas, just for people sitting in the back...unless those peopel are suckas...)
    07 F150 Extended Cab FX2 Sport
    Kenwood KDC-BT945U - And that's about it...
    dewey79's Avatar
    dewey79 is offline Junior Member
    Jan 2009
    ga
    28
    I have done it before, but I learned that you can get way more sound and better sound quality out of a good pair of component speakers running on a good amp than running four speakers.
    If you still want to play all four speaker, I would suggest another amp. I don't care for 4 channel amps. I prefer powerful 2 channel full range amps to power component speakers.
    Bottom line, you can do it, but I don't recommend it, your amp will get very hot and you might be doing both your amp and speakers a disservice
    shaneb's Avatar
    shaneb is offline CarAudio.com Veteran
    Aug 2008
    Fort Worth, TX
    2,437
    I wouldn't.
    The only possible room for lessened "sq" would be damping factor. But no one would be able to tell the difference.
    Sold To: L22rules; jeffrey1970; PABowhunter4life; allout13; atsaubrey; horsemanwill
    Bought From: brentbarrie; wgsj_fortvalley; horsemanwill; jaredspl; atsaubrey
    Reference Thread - http://www.caraudio.com/forum/showthread.php?t=365202
    Engine Whine Free Since 11.26.08
    Team Mafia "Killing the competition with silence"
    dewey79's Avatar
    Jan 2009
    ga
    28
    Just emphasizing what I said, you power two good speakers right, it will fill your whole car with sound. After I broke my kappas in, I couldn't tell that I didn't have speakers in the rear. Rear speakers are only needed when you don' have an amplifier, as a result, your speakers project a much smaller sound stage that does not fill the car.
    Back in the day, I heard some sony mobile es component speakers made out of aluminum like the infinity perfects, and I this guy put an amp on each one, it was the loudest, clearest thing I had ever heard in my life. On top of that, it had base that made it sound like subwoofers were in the car.
