Results 1 to 12 of 12
Reload Thread: voltage issue???
    i3abyjay25's Avatar
    i3abyjay25 is offline Get F'n Loud
    Aug 2002
    Dallas, Georgia
    38
    2,128
    1 Post(s)
    voltage issue???
    ok.. i have a 10.5 voltage w/ my car crunk.... NOT GOOD
    but i have a 12.5 w/ my car turn off...
    Why do i have more volt w/ the car turned off???????
    i know theirs isnt as much stuff on w/ the car off.. but neither is the alt... is that my alt id bad, or going bad???
    er1kkull's Avatar
    er1kkull is offline Senior VIP Member
    Jun 2003
    ALabama
    208
    go get your alt. checked at auto zone or some place like that more then likely its bad.........
    The Little People Beware!
    Head unit: Eclipse 5433
    Speakers: CDT CL61a the faded color matches my truck
    Amps: Kicker 800.2 KX and Kicker 200.2 KX
    Subwoofers: 2 12" Eclipse ALuminum Cone DVC 4ohm
    Second Skin Damlifier 50 Sq Feet. - Already Order
    Accessories: 20'1/0 KnuKonceptz.com, 17' 4 gauge Walmart , 20' Stinger Helix RCA cables (red), 20' Stinger Hyper series RCA cables, 1.0 Farad Lighting audio cap (waiting to buy new altenator)
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    Quote Originally Posted by i3abyjay25
    maybe u have too much of a load in ur electrical sys as the V goes down w the car on.
    If not, maybe ur batt/alt might be dying or something.
    just check how much ur alt puts out, and estimate how much current ur amps n anything electrical needs to run.
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    WTF is crunk?
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    er1kkull's Avatar
    Jun 2003
    ALabama
    208
    it is ebonic for car running (cranked).............
    nate_just_a_guy's Avatar
    nate_just_a_guy is offline Junior Member
    Aug 2003
    Bartow, FL
    39
    13
    check the alternator like was already said...then if need be have it beefed up at an alternator & starter shop your system will run like a champ with more amps...if you get the corny line
    i3abyjay25's Avatar
    Aug 2002
    Dallas, Georgia
    38
    2,128
    1 Post(s)
    ok. no i have replaced my stock 60 amp alt w/ a 150 amp alt.. i havbe the factory battery up front and a optima yellow in the back..
    i went yesterday to have my alt checked.. it tested fine.. putout 160 amps... they also checked my factory battery.. and they said it was fine as well...
    today i checked my optima battery... and the ground wire was very hot...which isnt right... so, when i got home.. i re did the ground wire.. ok...w/ the ground off the optima.. my stock battery tested in at 11 w/ it off... the optima tested in at 12.4 w/ no ground wire... w/ engine turned off....ok, w/ the optima ground off, i tried to start my engine... it wouldnt start.... i hook up the new ground.. it does start... but still have low voltage....
    what is it???
    er1kkull's Avatar
    Jun 2003
    ALabama
    208
    battery isolator?
  9. #9
    i3abyjay25's Avatar
    Aug 2002
    Dallas, Georgia
    38
    2,128
    1 Post(s)
    Re: voltage issue???
    Quote Originally Posted by er1kkull
    battery isolator?
    no, no battery isolater...
  10. #10
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    i suggest u upgrade your power wires....could be the culprit.....the 3 main wires should be upgraded
    alt to batt
    alt ground
    batt ground
    do that and see if that helps
  11. #11
    i3abyjay25's Avatar
    Aug 2002
    Dallas, Georgia
    38
    2,128
    1 Post(s)
    Re: Re: voltage issue???
    Quote Originally Posted by Goddyd4me
    alt to batt
    alt ground
    batt ground
    ive already upgraded the alt to battery.. 8 g to 4 g...
    the alt ground.. is hooked in a plug... which consists of 2 other wires.. so, how do u i upgrade it???
    battery ground.. will upgrade today...
  12. #12
    60_cent's Avatar
    60_cent is offline CarAudio.com Elite
    Mar 2003
    atlanta, GA
    1,392
    Quote Originally Posted by maylar
    WTF is crunk?
    It is an ATL (Atlanta) thang, you wouldn't understand...
  1. how to increase voltage
    By marleyskater420 in forum Amplifiers
    Last Post: 08-05-2003, 02:29 AM
  2. preamp voltage
    By DaBaller504 in forum General Discussion
    Last Post: 08-03-2003, 07:00 PM
  3. a weird problem with my car radio
    By bigmiao in forum Wiring, Electrical and Installation Help
    Last Post: 07-17-2003, 10:16 AM
  4. Decrease in Voltage Capacitor
    By Clarion_Guy in forum General Discussion
    Last Post: 07-16-2003, 11:07 PM
