Results 1 to 5 of 5
Reload Thread: 4 channel amp with 2 dvc's
    DiB's Avatar
    DiB
    DiB is offline Meber
    Mar 2003
    San Diego
    35
    221
    I just got my 2ohm 4kw hooked up to my 2 crossfire xt's. They are 1.4 ohm dvc subs. It's hooked up with my amp running 4 channels bridged to 2 channels and running at 2.8 each. I'm wondering if I should just run each channel to each coil or if it it's best the way it is now. I don't want to risk blowing anything up even though it would be covered. In theory it should work but I'm wondering if the cable lengths need to be exact if I run each channel to each coil.
    jbl_marshall21's Avatar
    jbl_marshall21 is offline important person
    Oct 2002
    nebraska
    2,494
    1 Post(s)
    bridge the channels and just run one sub per channel. its not good to run a channel to each vc. cuz some people say its not the exact same signal.
    one sub a channel.
    Alpine CDA-9886
    RUX-C701
    PXA-H701
    JL xr-650csi
    JL vr-650cxi
    2 8" W7
    JL HD750/1
    JL HD600/4
    2007 Chevy Trailblazer
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,244
    1 Post(s)
    309 Post(s)
    well...unless the gain is set exactly the same running a vc to each channel can be hazardous
    DiB's Avatar
    DiB
    Mar 2003
    San Diego
    35
    221
    I always thought the same thing. On this amp though the gain would be the same. Right now I can either run at a 2.8 ohm load or a 0.7 ohm load. I don't think it would like 0.7 ohms. I would think if I could get each channel at 1.4 ohms I would get optimum power from this amp and to my subs.
    DiB's Avatar
    DiB
    Mar 2003
    San Diego
    35
    221
    Found my answer. It's amp dependent and in my amps case the gain would be negligible to wire each channel to each coil, like a 6 watt increase.
  1. 4 channel amp on dvc subs?
    By pimpedoutblazer in forum Wiring, Electrical and Installation Help
    Last Post: 07-22-2003, 05:12 PM
  2. SIMPLE QUESTION ON 4 channel amp
    By drpain714 in forum Wiring, Electrical and Installation Help
    Last Post: 07-22-2003, 01:07 PM
  3. 5 channel amp with factory deck
    By vallan in forum Wiring, Electrical and Installation Help
    Last Post: 07-15-2003, 05:18 AM
