Results 1 to 5 of 5
Reload Thread: wire size..... 2 amps
    er1kkull's Avatar
    er1kkull is offline Senior VIP Member
    Jun 2003
    ALabama
    208
    I am trying to get everything i will need for my install before i order everything.... and right now i have a kicker 800.2 with 4 gauge wire feeding it.... i plan to get the usx 2080 for my comp set..... it says i need a 15 amp fuse while i already have a 150 amp fuse for the kicker 800.2 but kicker only recommends a 120 amp fuse..... so can I still use that 4 gauge to feed both and when i get near the amps i use a distribution block and put a 120 amp fuse to the 800.2 and a 15 amp fuse to the 2080? and it still have enough current to push both my amps to the extend or should i buy another 1/0 amp kit.... i found a stinger 1/0 amp kit with 18 feet of power 3 feet of ground another anl fuse holder with a 250 amp fuse all for 90 bucks....... i would perfer to keep the cost down so if you know another kit if i need 1/0 please tell me
    thanks for ur time...
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    30
    873
    How much is the USX 2080 putting out rms?
    I would recommend that u use atleast a 2ga wire running towards the subs with a 250a fuse close to the battery. U don't need to put fuses at the distribution block because the large fuses are there to protect your car not your amps, the onboard fuses on ur amp protect your amp.
    I would personally get the 1/0 amp kit. I would run the 1/0 as long as you could then distribute into a 2ga | 2ga. With one of the 2ga going to the kicker and the other 2ga to the USX, or u could use 4 ga to the USX because it does not seem to use much power if all it uses is a 15amp fuse. That would ensure that u are getting the adequate draw from your amps.
    Oct 2002
    Fort Meade, MD
    30
    873
    Oh yeah grounding both the amps in the same place would be good too. i would use no less than 2ga for the kicker and 4ga for the USX
    er1kkull's Avatar
    Jun 2003
    ALabama
    208
    should i need 4 gauge for the USX 2080 its 80watts by 2
    The Little People Beware!
    Head unit: Eclipse 5433
    Speakers: CDT CL61a the faded color matches my truck
    Amps: Kicker 800.2 KX and Kicker 200.2 KX
    Subwoofers: 2 12" Eclipse ALuminum Cone DVC 4ohm
    Second Skin Damlifier 50 Sq Feet. - Already Order
    Accessories: 20'1/0 KnuKonceptz.com, 17' 4 gauge Walmart , 20' Stinger Helix RCA cables (red), 20' Stinger Hyper series RCA cables, 1.0 Farad Lighting audio cap (waiting to buy new altenator)
    Oct 2002
    Fort Meade, MD
    30
    873
    no not really 8guage should do fine for that amp. i just like to go overboard
  1. remote wire
    By rollinhard22s in forum Wiring, Electrical and Installation Help
    Last Post: 10-31-2004, 07:42 PM
  2. how to wire up my amps?
    By RFmustang in forum Wiring, Electrical and Installation Help
    Last Post: 10-03-2004, 02:22 PM
  3. what size box??
    By BIGGUP21 in forum Enclosure Design & Construction Help
    Last Post: 07-18-2003, 04:52 PM
  4. How do I wire this?
    By Sw1tched in forum Subwoofers
    Last Post: 07-17-2003, 07:09 PM
  5. remote wire
    By LuNaTiC in forum General Discussion
    Last Post: 07-15-2003, 01:03 PM
