Results 1 to 5 of 5
Reload Thread: 93 K5 Blazer Install
    LILMAN's Avatar
    LILMAN is offline Member
    Dec 2006
    Hartford
    36
    Can anyone help me with the wiring in my full size Blazer? I have 2 separate harnesess but I don't know what connects to what. The truck has 2 amps connected already. I'm putting in an Alpine CDM9820 (or something like that). The Eclipse that came with the truck did not work at all when I first got it.
    southwest713's Avatar
    southwest713 is offline Senior VIP Member
    Dec 2004
    Houston, TX
    464
    Re: 93 K5 Blazer Install
    which harnesses do you have? is it the one that plugs in to the back of the radio and then the one that goes to the plug on the car? if so then you should just be able to match the colors. and you say there are 2 amps in there, so you'll just have to connect the rca's to the back of the radio. if one amp is for subs just connect it to the sub out and if the other amp is for the door speakers connect that to the front output.
    Refs:
    arabretard...MoeLester...Vincent9515...Davidfre21. ..midwestcustoms3...jciu...qcsfinest704...alxmlr78 9...bigbirney420
    System in Progress:
    H/U: Eclipse CD5030
    Comps: Front: Image Dynamics CXS64 / Rear: Infinity Kappa 6.5s
    Subs: 1 12" IDMax
    Amps: AudioQue 1200D & Eclipse XA4000
    LILMAN's Avatar
    Dec 2006
    Hartford
    36
    The truck has 2 harnesses that come from a box under the dash. one of them looks like it was connected and the other looks like it was just cut off and not used.
    Truck Harness wires
    red, yellow, orange, white, black, brownish grey color
    Other truck Harness thinner wires(not connected to anything)
    yellow, white, white/black, green, black, lighter brownish color
    Alpine harness
    black, yellow, red, blue, blue/white, green, green/black, purple, purple/black, white, white/black, grey, grey/black
    If anyone can tell me what connects to what let me know. I don't want to drive thru the winter in silence. Thanks
    Dec 2004
    Houston, TX
    464
    well that box is most likely the factory amp.
    easiest thing to do is just buy the harness for your car which should be ~$20
    and that harness will have the same colors as the alpine and you just match those together.
    wait if it already had an eclipse, how was that one connected? you should already have the harness then
    Refs:
    System in Progress:
    H/U: Eclipse CD5030
    Subs: 1 12" IDMax
    LILMAN's Avatar
    Dec 2006
    Hartford
    36
    I went to Circuit City to get another harness and it wasn't the same as the one I have.
    I hooked up the wires and they didn't work either. Could there be another reason the deck didn't work?
