Results 1 to 4 of 4
Reload Thread: 2 channel amp powering a single sub??
    BIGGUP21's Avatar
    BIGGUP21 is offline Member
    Jan 2003
    Allentown, Pa
    136
    I am going to be powering my 12" Brahma with a Lanzar Opti500.2
    This amp does 900 watts bridged @ 4 ohms and it does 450x2 @ 2 ohms. What do you guys think will be better:
    A) bridge the amp and wire the sub to 4 ohms.
    B) put a channel on each voice coil separately.
    The main reason I am asking is because would the amp draw less current if it isn't bridged and running at its full potential.
    mgaidica's Avatar
    mgaidica is offline CarAudio.com Veteran
    Jan 2003
    Northville, MI
    3,065
    well it will pull the same amount either way.. if ur sending 450 to each coil, or 900 to both, it will pull the same.. ide just stick mono, for ease of wiring, and if u have settings for each channel it would be tricky..
    2x JBL 1200.1 for sale...
    AIM- Mgaidica
    BIGGUP21's Avatar
    Jan 2003
    Allentown, Pa
    136
    OK thanx for the info. I totally forgot about having setting for both sides. Thanx again
    LuNaTiC's Avatar
    LuNaTiC is offline 18 to make up for below.
    Jun 2003
    MA
    31
    1,589
    Also, wiring the coils to two different channels can make the sub tear itself a part. In music sometimes both channels are recieving different notes at the same time. When a sub tries to produce two different sound at the same time it can destroy itself.
    97' Ford Probe..
    Sub - 2 18" FI BTL's shipping at this moment.
    Amp - undecided, help plz
    H/U - Kenwood Excelon x779
    Wiring - Lots of 1/0 gauge, where should I buy from?
    Box Specs - Dunno yet
    Quote Originally Posted by dleccord
    i drive at the speed limit... this way i can listen to music longer
