Results 1 to 6 of 6
Reload Thread: voltage problems.
    overdose's Avatar
    overdose is offline Junior Member
    Jun 2003
    canada
    voltage problems.
    I have 2 alpine type s 10" subs that are 200w @ 4 ohms. I have a RF (200m) amp that is mono at either 100W @ 4 ohm or 200w @ 2 ohm.(the subs are hooked up in parralel) I am having problems with the voltages in my car as my check engine light keeps coming on. I am not sure if the amp is set at 2 or 4 ohm... by doing the v=ir ohm's laws **** I am presuming it should be @ 4 ohm. is this right? and even then wouldn't the subs be running at 2 ohm?
    Is my battery or alternator going?
    or is it my setup?
    PS I have a 2001 jetta GLS (2.0 litre one). If that helps.
    nswartley's Avatar
    nswartley is offline Down and out...
    Nov 2002
    (Near) San Jose, CA
    31
    5,879
    that amp is way too small to cause any voltage problems...try going around for a little while with the head unit off and see what happens.
    -nate
    overdose's Avatar
    Jun 2003
    canada
    I took a long drive and the light went away.
    but driving in the city on short trips all week it seems to come back.
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    What makes you thing it's a voltage problem at all? The Check Engine light is from the car's computer... could be lots of things.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    overdose's Avatar
    Jun 2003
    canada
    well, b/c it started about an hour after I had the stereo installed.
    that and I just had it in for maintainence a few weeks ago.
    Aurorav8's Avatar
    Aurorav8 is offline CarAudio.com Elite
    Apr 2003
    Fort Wayne
    39
    1,610
    If your check engine light keeps coming on take to some place that will hook it up to a computer. The car stores the codes it sends out so they will be able to tell you exactly what is wrong with it.
