Results 1 to 3 of 3
Reload Thread: Amp install question
    stylez777's Avatar
    stylez777 is offline Member
    Apr 2007
    Queens, NY
    67
    I am installing my first amp and had few questions. The amp is 5 channel 1800w max 900w rms.
    1: In the instructions it say the power connection is 8 guage. Do I have to use 8 gauge or can I use thicker like 4 or 1/0?
    2: The amp has 2 40 amp fuses in it. When installing the power cable is it correct to use an 80 amp fuse? or should i use a different amp fuse?
    Da64u's Avatar
    Da64u is offline Senior VIP Member
    May 2007
    Fort Lauderdale, FL
    410
    71 Post(s)
    Re: Amp install question
    Quote Originally Posted by stylez777 View Post
    if you use anything thicker than 8 gauge wire it probably wont fit
    waltech's Avatar
    waltech is offline Mobile Tech Rep
    Jul 2008
    South Hackensack, NJ
    The bigger the better when it comes to wire thicknes. If you can fit the connector for 4 gauge you will be better off. The 80 amp fuse will give you proper protection.
