Results 1 to 4 of 4
Reload Thread: Complicated wiring question, need some advice
    junocdx's Avatar
    junocdx is offline Senior VIP Member
    Jan 2003
    AR
    31
    227
    Hey everyone. I have an idea that I want to bring to life, but not quite sure if it will work or not, so I need some of you electrical wiring wizards to help me out. Ok... heres my situation
    I made my own little bass-blockers for my front speakers in my truck with 2 10uF capacitors. It's supposed to cut off the frequencies below 2K hz. It works VERY good, especially for only $.99 a piece at Radio Shack, but they tend to send the highs a little TOO loud. Anyway... I want to rig up a switch to turn my amp on and off (bastard police ) Now my problem is.. I also want to be able to like disconnect those capacitors from the front speakers at the same time, so I can just use the regular speakers to play a little bass while my subs are out.
    It really isn't all that important or neccessary, but its summer, no school and nothing to do. I got the idea and I want to make it work. If anyone can tell me how I would go about doing this or if it's even possible, please get to me ASAP and tell me about it!
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    You'd need a 3-pole switch, which is a real oddball. 4PDT switches are available, but not real common.
    A simpler solution is use a double-pole switch to short out the capacitors, and a separate switch to interrupt the remote signal from the amp.
    If you insist on having only 1 switch, you could do it this way...
    A double pole switch - one circuit runs a DPDT relay, the other circuit switches your remote. The relay contacts would short out the caps. Or, use a SPST switch and a 4PDT relay...
    You get the idea. You need 3 switch circuits total.
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    fantomas's Avatar
    fantomas is offline show her the oh face
    Apr 2002
    CT
    33
    980
    4 Post(s)
    if you can understand this relay schematic i just drew up in 5 minutes......
    when in doubt, check the ground.
    1728
    mgaidica's Avatar
    mgaidica is offline CarAudio.com Veteran
    Jan 2003
    Northville, MI
    3,065
    i know how... uses one switch (for the caps), hot me up on AIM.
    2x JBL 1200.1 for sale...
    AIM- Mgaidica
