Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Reload Thread: is this the correct way to wire 2 12' Dual 4ohm Pioneer Premier TS-W1207D4 ?
    jamezruiz's Avatar
    jamezruiz is offline Member
    Jun 2008
    Russellville, AR
    43
    okay, so the guy who wired my subs, said that if i wired the 2 DUAL 4ohm speakers directly to a 2 channel amp , that it would produce an 8ohm load, is that true??
    he wired my subs down to 2ohm and wired them in series, and said that the amp, would give me a 4ohm load. because 2ohm+2ohm= 4ohm LOAD is that true??
    the subs specification are Dual 4ohm, and 400rms.
    the amp is 2x200 rms at 4ohm , 2x400rms at 4ohm, 1x800rms at 4ohm bridged 2x300rms at 2ohm
    revrider1's Avatar
    revrider1 is offline Hmmm...
    Jul 2005
    Down South~3rd Coast~TX
    39
    29,519
    2 Post(s)
    Re: is this the correct way to wire 2 12' Dual 4ohm Pioneer Premier TS-W1207D4 ?
    If they are Dual 4ohm subs then each sub would produce a final 2ohm load to the amp per channel.
    01 S 10's Avatar
    01 S 10 is offline LOUD
    Jan 2008
    Central Florida
    30
    4,278
    2 Post(s)
    http://www.crutchfield.com/learningc...4%2Dohm%5Fmono
    wire them like that to get your 800w @ 4 ohm (bridged of course)
    -2005 GMC Sierra SLE crew cab
    -Pioneer Avic-d3, factory BOSE
    jamezruiz's Avatar
    Jun 2008
    Russellville, AR
    43
    so BRIDGE devides the 800w x 1 4ohm
    to 2 x 400rms ???
    my subs needs 400rms each.
    and the diagram u showed me , is a MONO AMP. mine is a 2 Channel amp.
    here is the picture of how the setup is now.
    http://i63.photobucket.com/albums/h1...z/DSC00435.jpg
    jrwalte's Avatar
    jrwalte is offline CarAudio.com Elite
    Jan 2008
    GA
    985
    That's why he said to bridge it.
    System:
    Pioneer P800PRS, 180A EA HO Alt, Kinetik HC1400
    Memphis ST1500D, Eclipse 4100
    RD 15" Elite, Polk MMC6500
    Not running active...yet
    jamezruiz's Avatar
    Jun 2008
    Russellville, AR
    43
    well the guy that wired my thing said he set the 4ohm subs down to 2ohm and bridged them, i'm confused
    jamezruiz's Avatar
    Jun 2008
    Russellville, AR
    43
    so i am getting 300rms ??
    jamezruiz's Avatar
    Jun 2008
    Russellville, AR
    43
    i'll have the guy rewire them the DIAGRAM way lol as suggested by 01 S10
  9. #9
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,022
    1 Post(s)
    266 Post(s)
    Quote Originally Posted by jamezruiz View Post
    FWIW - you don't bridge subs, you bridge amps.
    However - if he wired each subs' coils in parallel for two ohms, then the subs in series for a total resistance of 4 ohms, and bridged the amp - it's set up the way it should be.
  10. #10
    jamezruiz's Avatar
    Jun 2008
    Russellville, AR
    43
    Quote Originally Posted by n2audio View Post
    okay he did exactly that, so they are indeed getting 400rms each sub, the recomended by the premier subs manual. i was just worried because i posted some videos on youtube and they said they were underpowered
  11. #11
    jamezruiz's Avatar
    Jun 2008
    Russellville, AR
    43
    maybe they look under powered because they havent been "broked in" yet, i've had the setup for about 5 days
  12. #12
    jamezruiz's Avatar
    Jun 2008
    Russellville, AR
    43
    here is a video of my system in action, tell me what u guys think, thanx
    http://youtube.com/watch?v=hS2cUQyRQpc
  13. #13
    n2audio's Avatar
    Dec 2001
    Lawrence, KS
    5,022
    1 Post(s)
    266 Post(s)
    Oh - your amp -- It's WAY WAAAY too small for any good pair of 12's. All of Lanzar's non-Optidrive amps market their max power ratings which tell you NOTHING about what the amp can actually do.
    You need to look at the RMS ratings on cheap amps. If you can't find them there's probably a reason. The Vibe 226 produces 160w. You would need the 276 or 286 to wake those subs up. However, if you're going to consider an amp upgrade I would suggest a good quality class D mono amp that does 800-1000w at 1 ohm. The Lanzar Optidrive 1400D is a quality amp for around $200, but there are many other good options.
  14. #14
    jamezruiz's Avatar
    Jun 2008
    Russellville, AR
    43
    yeah, i guess i should of asked on to what kind and how big my amp should of been before buying this vibe226 , i looked into this http://www.onlinecarstereo.com/CarAu...roductID=14078
    seems like it gots good reviews, but i have a limited budget, can u point me towards a good amp that will wake up my subs? but that wont hurt my wallet?
    is this one that u were reffering to? http://www.caraudiodeals.com/lanzar-...ier-p-370.html
    the thing is that i dont want to blow up my subs, that are rated at 400rms and are dvc 4ohm, i currently have the Vibe 226 bridged in series its supposed to divide 800 wts
  15. #15
    GearGuy2001's Avatar
    GearGuy2001 is offline CarAudio.com Veteran
    Apr 2006
    South Beloit, IL
    29
    2,395
    1 Post(s)
    If you can find a used Sundown 1000d that will wake up em (1000w rms @ 1 ohm) I got mine used from the forums here for $210 shipped
    Team D.O.A.
    2009 BMW 335xi
    System to come?
    References: http://www.caraudio.com/forum/showthread.php?p=4811364
