Page 3 of 3 FirstFirst 1 2 3
Results 31 to 34 of 34
Reload Thread: Will this do the same thing as a audiocontrol line driver?
  1. #31
    jeeper2269's Avatar
    jeeper2269 is offline Senior VIP Member
    Mar 2007
    Somewhere, OR
    156
    29 Post(s)
    Re: Will this do the same thing as a audiocontrol line driver?
    Just to clarify one thing. I don't want to change the head unit out. I really like the way the stock one looks. All the aftermarket head units I have seen installed on the newer Tacomas look like crap.
  2. #32
    jeeper2269's Avatar
    Mar 2007
    Somewhere, OR
    156
    29 Post(s)
    Quote Originally Posted by helotaxi View Post
    This was with the amp gain all the way down?
    So, I finally messed around with the gains after reading some articles on here and the dead noise is gone. Yes, I made a mistake and found that the gains on the component amp were set mid way. I turned everthing all the way down and messed with it for about an hour. The fronts are sooooo much louder, and better sounding than they were. I still have to mess with the sub though. I got the line driver, and may install it, but I have to get some time to do it. Thanks for all the info.
  3. #33
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    You got the front sounding good. Great!. You should easily be able to do the same with the sub without the line driver. That is the route that I recommend. Adding another component is only going to increase the potential for introuced noise to the system. You don't get rid of noise by adding components to the system.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
  4. #34
    Rashaddd's Avatar
    Rashaddd is offline Terrrrrist
    May 2008
    Sacramento
    5,095
    Why don't you just buy an aftermarket HU...?
    I'm sure you can find one that looks just fine, or that you'll get used to
