Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 34
Reload Thread: Will this do the same thing as a audiocontrol line driver?
  1. #16
    jeeper2269's Avatar
    jeeper2269 is offline Senior VIP Member
    Mar 2007
    Somewhere, OR
    153
    27 Post(s)
    Re: Will this do the same thing as a audiocontrol line driver?
    I am probably just going to have to bite the bullet and spend the extra cash. Thanks for the help guys.
  2. #17
    lilmaniac2's Avatar
    lilmaniac2 is offline Ask Me about SI Mag V4!
    Jan 2006
    Somewhere, Else
    30
    15,930
    I have a audiocontrol overdrive ill sell you for 75 shipped pm me if interested
  3. #18
    djman37's Avatar
    djman37 is offline SOLID
    May 2004
    DFW, TX
    8,344
    navone LOC if you're gonna use one.
    http://www.davidnavone.com/cart.asp?24&cat=7
    Doug Blohm
    Team Southern Bass
  4. #19
    jeeper2269's Avatar
    Mar 2007
    Somewhere, OR
    153
    27 Post(s)
    Quote Originally Posted by lilmaniac2 View Post
    check your messages..
  5. #20
    jeeper2269's Avatar
    Mar 2007
    Somewhere, OR
    153
    27 Post(s)
    I tried the 3/4 volume, setting the loc channels,, it did not work. As soon as I moved the fronts up at all, and I mean barely turned, it screamed. WAAAYYYY tooo loud. I am hoping the audio control will get rid of this problem. I am really surprised there aren't as many people with the same problem, or faced it anyway.
  6. #21
    jeeper2269's Avatar
    Mar 2007
    Somewhere, OR
    153
    27 Post(s)
    Quote Originally Posted by djman37 View Post
    If I get the audio control line driver, will I still need the LOC?
  7. #22
    forbidden's Avatar
    forbidden is offline CarAudio.com Elite
    Jan 2004
    CFB Comox, BC, Canada
    49
    1,127
    If you use the LC6i or the 6XS, you will not need a LOC. The overdrive is a 2 channel interface, not what you are looking for in this case. Good deal, wrong device for the application.
    Yeah, whatever
  8. #23
    Tehgregzor's Avatar
    Tehgregzor is offline Enjoys loud noises.
    May 2005
    Murray,KY
    30
    1,364
    6 Post(s)
    Why no headunit?
    95 Trans Am Convertible
    LT1 Corvette Motor
    My brand new project. Literally the most stock system i've had since 16.
  9. #24
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    42
    8,933
    Quote Originally Posted by jeeper2269 View Post
    This was with the amp gain all the way down?
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
  10. #25
    Eugenics's Avatar
    Eugenics is offline Princess
    Jul 2005
    Arbys
    23,904
    Quote Originally Posted by Tehgregzor View Post
    Why no headunit?
    for not much more you could have one and the added features, unless you're going for the OEM look.
    crunktimes . com/ct
  11. #26
    Speedbump3's Avatar
    Speedbump3 is offline Banned
    Jun 2008
    Lounge
    2,830
    That LOC should work fine, but if your hell bent on a different oem integrator, I suggest and RF 3sixty unit. You get some good tuning features.
  12. #27
    jeeper2269's Avatar
    Mar 2007
    Somewhere, OR
    153
    27 Post(s)
    I am completely confused here. Some say that the line driver will help, some say that it will damage my amps, what the heck?
  13. #28
    tez4life's Avatar
    tez4life is offline Premium Member tez4life is a Supporting Member of the forum!
    Nov 2006
    Mobile, Al
    3,937
    9 Post(s)
    I had a similar issue with the Loc I was using when I first bought my Crown Vic. Had a cheap unit from Walmart.
    The Loc only put out 2 volts and the amp I was using (Mtx 342) required alot of input voltage to keep the gains down.
    Leaving the gains on the Loc up gave me the same noise issue that your having. I installed my Audiocontrol Four1 EQ/Linedriver and it fixed the problem off the top.
    Gave me plenty of gain and voltage for my amp, and let me keep the LOC gains so low, noise no longer became a issue.
    I would suggest the linedriver from lilmanic2 because its cheap and works wonderful.
    But, honestly for what your spending, you could get a nice HU to replace all that. But I still use my linedriver in all my installs.
    Refs and feedback (pre Itrader) on here http://www.caraudio.com/forums/buyer-seller-feedback/348682-tez4life-refs-feedback-thread.html
    Caraudioclassifieds.org feedback http://www.caraudioclassifieds.org/forum/members/tez4life/
    Ebay feedback http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&userid=tez4life&ftab=A llFeedback
  14. #29
    helotaxi's Avatar
    Dec 2003
    42
    8,933
    There is no need for a line driver. If there is good output with the amp gain way down and the LOC gain almost at min, the the linedriver does absolutely nothing for you.
    Turn the amp gain all the way counter-clockwise. Turn all the trimmers on the LOC all the way counter-clockwise. Turn up the volume to 3/4 on your radio. Unhook the speakers from the amp and hook a DMM on VAC to the right front output on the amp. Play a 0dB test tone and slowly adjust the LOC trimmer until you have the voltage that you should have for rated output from the amp. If you can't get full voltage that way, increase the gain slightly. Based on you first post you had the gain structure WAY messed up in your system. Adding another component is not the answer to a tuning problem.
  15. #30
    jeeper2269's Avatar
    Mar 2007
    Somewhere, OR
    153
    27 Post(s)
    Quote Originally Posted by helotaxi View Post
    "DMM on VAC" means what?
    sorry, I don't understand.
