Results 1 to 12 of 12
Reload Thread: Dual 4 coil subs, want to run 4ohm but not working??
    Warrior's Avatar
    Warrior is offline Member
    Apr 2003
    WI
    35
    54
    OK guys my subs/amp is in my sig. I got it all hitched up finally with the help of a friend.
    Right now I just have the subs hitched up like normal speakers, the + and - of one sub to each speaker terminals on the amp (left and right).... But I have 2 speaker terminals sets on each sub....
    I tryed this:
    but it didnt work... nothing came outa my speakers??
    So I tryed this:
    And nothing came outa my speakers.
    What am I doing wrong??? The way I have it hitched up now with just 1 set connected to the amp, it hits pretty good, but for how much power this amp and sub combo put out, i should be hitting A LOT harder. Especially when my friend has a cheap *** amp, 400watt pioneer immp sub hitting harder.....
    Could anybody show me some REAL PICTURES of REAL SETUPS wiring for that Dual 4ohm load? please please !!
    '97 Avenger
    K&N Filter
    Avenger Decals
    Tinted Windows
    Sony CA400 HU (50x4watts)
    Sony Xplod 5 1/4s (140watts ea.)
    Jensen 6x9s (180watts ea.)
    2 Pioneer Premier 10" Subs (800watts ea.)
    1 Pioneer Premier PRS-X720 Amp 400watt x 1 @ 4ohms (under-rated)
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    Re: Dual 4 coil subs, want to run 4ohm but not working??
    I tryed this:
    So I tryed this:
    hmmm, you didn't say if the amp had power (LED light). Even though the ohmload might be different, it SHOULD by right, play for a bit.
    As for wiring,
    http://forums.caraudio.com/vb/showth...threadid=31984
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
    Warrior's Avatar
    Apr 2003
    WI
    35
    54
    Yeah, the amp works great. It can be briged at 4 ohm x1 or 2ch. x 2ohms or 4ohms. I want it 4ohm x 1.
    but you see i dont get how the hell you put 1 + wire from the speaker terminal to 2 other + terminals on the subs? when there is only 2 ends to a wire??
    '97 Avenger
    K&N Filter
    Avenger Decals
    Tinted Windows
    Warrior's Avatar
    Apr 2003
    WI
    35
    54
    for the 4 ohm load, should I just run the + end to the far sub first, then slice some of the wire open in the middle and put it in the other + end of the other sub? and same with with the - wires correct?
    also, i should put that on the BRIDGED channel for the amp right?
    '97 Avenger
    K&N Filter
    Avenger Decals
    Tinted Windows
    cobra65427289's Avatar
    cobra65427289 is offline CarAudio.com Veteran
    May 2003
    IL
    31
    2,341
    im not sure but when wiring a dvc sub you should hook a wire up to the possitive and from that possitive run to the negative for the other voice coil of the sub. not sure, just putting in my 2 cents.
    Warrior's Avatar
    Apr 2003
    WI
    35
    54
    So should I run this:
    Sub 1: Short speaker wire from voice coil 1 - to voice coil 2 +
    Sub 2: Short speaker wire from voice coil 1 - to voice coil 2 +
    then.
    Hitch up + from sub 1 to + sub 2
    Hitch up - from sub 1 to - sub 2
    what is that though? is that a 4ohm load or a 2ohm load? I would connect that to the amp as "Bridged" right?
    '97 Avenger
    K&N Filter
    Avenger Decals
    Tinted Windows
    May 2003
    IL
    31
    2,341
    im not 100 percent sure on this because i've only really been deeling with single voice coil subs. but i believe it would be a 4 ohm load if you dont bridge the amp, use the 2 channels from the amp, so just use the 2 negative outputs and the 2 positive outputs. again i'm not completely sure.
    Warrior's Avatar
    Apr 2003
    WI
    35
    54
    I'll try it!
    '97 Avenger
    K&N Filter
    Avenger Decals
    Tinted Windows
  9. #9
    May 2003
    IL
    31
    2,341
    i dont think i would try it, i think i would wait for someone else to put in their knowlege. please dont try it, i am usually wrong about things like this
  10. #10
    paikiah's Avatar
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    I say hold on for about an hour an half, until I get myself to the base, in front of the PC and read your question again...
    Still at home, groggy...
    ok, getting ready.. :p
    Team Caraudio
    Sony C90, 210 EQ
    RF 60.2 amp
    eD A15.22
  11. #11
    paikiah's Avatar
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    The amp works great? How do you know if there's no sound to it? Check for power LED at the sides.
    Also, 1 + wire to 2 other terminals is easy. Get another wire, shove it into the terminals. If your subs are not the plug type, then solder two wires together onto a terminal.
    You can't avoid this procedure, if you're wiring dual vociecoil subs. It's all a matter of trying to keep it clean. You could ALSO try to get a terminal cup with 8 posts (I have it, but not much use), link ALL that individually to your subs, and configure your wires from the cup itself. Either way, you're gonna have a lot of wires hanging out of the subs.
    As for your subs (they are 4ohm DVC), the first wiring diagram is correct to get 4 ohms. Just another example to confirm this:
    Team Caraudio
    Sony C90, 210 EQ
    RF 60.2 amp
    eD A15.22
  12. #12
    Warrior's Avatar
    Apr 2003
    WI
    35
    54
    Ok i'll try it again. The amp works because ther is a power led and I do get power from it because right now I have it hitched up .... just with only 1 set of terminals on each speaker plugged into the amp...
    '97 Avenger
    K&N Filter
    Avenger Decals
    Tinted Windows
