+ Reply to Thread
Page 7 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 91 to 105 of 234
Reload Thread: voicecoil wiring options
  1. #91
    mike75356's Avatar
    mike75356 is offline CarAudio.com Elite
    May 2005
    pittsburgh
    1,205
    Re: voicecoil wiring options
    Ok.......... so how would you wire a 13 w7 at 3 ohms off a pa a3000db?
  2. #92
    dkguitarist's Avatar
    dkguitarist is offline CarAudio.com Veteran
    Oct 2004
    Oklahoma City, Oklahoma, United States
    28
    5,019
    my bad. -+ -+. just think of it as a dual 2 ohm driver. ++ -- will be 1 ohm (.75 for 13w7) and +- +- will be 4 ohm (3 ohm for 13w7). someone correct me if i'm wrong.
    2003 Chevy Cavalier
    HU:880PRS - SUB AMP: IA 20.1 - SUB: 13w7 (15" 05 XXX awaiting new box)
    FOR SALE: USHER 9950 TWEETERS, USAMPS HCA-25 2 CHANNEL, XXX XBL^2 6.5" MIDS, Kicker KX300.2 amp
    Refs: zachzchw, AcidicDreams, Mr Tibbs, Mr Teacha, vetkilr, Blunt, Showrides, Mihklo, QtrHorse, vosschs, nvruckus, jeeper07, sakura, iceteebone, 2loud4u, eatank, brents, bookechu, young_gun, maldecido33, pickup1, angryeric116, go_go_thrash, gentlejax, superblack350z, and 100% ebay feedback. (dkguitarist454)
  3. #93
    BigSquid10's Avatar
    BigSquid10 is offline Member
    Jul 2005
    Delaware
    37
    I need to know how to wire this combo or should i get a 2 channel amp thanks!!
    Sub: Kicker Model: 05CVR124
    * 12" Subwoofer with dual 4-ohm voice coils
    * Suitable for marine use or harsh automotive environments
    * Double-stitched, foam-ribbed Santoprene rubber surround
    * SoloKon aluminum-treated composite cone with Santoprene surround
    * High density ultra-stiff basket
    * Power handling: 400 RMS watts (200 watts per voice coil)
    * Peak power: 1500 watts
    * Frequency response: 20-200 Hz
    * Sensitivity: 88 dB@1w/M
    * Mounting depth: 6-5/8"
    * Sealed enclosure volume: 1.00-2.00 cubic feet
    * Vented enclosure volume: 1.75-3.25 cu. ft.
    And amp: Audiobahn Model: A8000T
    Class A/B MOSFET Circuitry
    PWM MOSFET Power Supply
    Semi-Double Sided Glass Epoxy Circuit Board
    THD : 0.02%
    S/N Ratio > 100dB
    Frequency Response : 10Hz - 40Hz (+ / - 1dB)
    Variable 18dB High Pass Crossover : 50Hz- 750Hz
    Variable 18dB Low Pass Crossover : 50Hz- 120Hz
    Bass boost on / off
    Subsonic Filter :20Hz - 50Hz
    RCA Throughput Connections
    3-way Protection Circuitry : Thermal, Short Circuit, Overload, Cooling Fans
    Cobalt Blue Illumination
    High Gloss Chrome Plated Finish
    Nickel Plated Block Terminals
    Air Induction Fan Cooled
    RCA and Speaker Level Inputs
    4 Ohms Stereo : N /A
    2 Ohms Stereo : N /A
    4 Ohms Mono : 800 x 1
    2 Ohms Mono : N /A
    Dimension(H x W x D) : 1 7/8" x 9 7/8" x 11 7/8"
  4. #94
    azbass's Avatar
    azbass is offline the salty ca.com mod
    Sep 2004
    Long Beach, CA
    34,958
  5. #95
    azbass's Avatar
    Sep 2004
    Long Beach, CA
    34,958
    Quote Originally Posted by mike75356
    you wouldnt.
  6. #96
    BigSquid10's Avatar
    Jul 2005
    Delaware
    37
    so if i have a dual voice coil sub how do i get 4 ohms i see in the pics 4 ohm =2ohm load and 2 ohm = 4ohm so would that be it? and if i have a 800 watt mono amp it says " 4ohms Mono : 800 x 1 " so it would be - to + to the sub then the other - and + go straight onto the amp to split them up to 2 ohm load to each coil so it would equal 4 ohms?? right thanks!
  7. #97
    Oct 2004
    28
    5,019
    Quote Originally Posted by BigSquid10
    depends on if your sub is dual 2 or dual 4 ohms. then find the diagram for your impedence sub, and wire it like it shows to 4 ohms. but it seems like you have a dvc 2 ohm sub so wiring it in series would get your 4 ohms you want.
    2003 Chevy Cavalier
  8. #98
    BigSquid10's Avatar
    Jul 2005
    Delaware
    37
    ok im really really confused that my head is on fire lol. my amp says 500 watts RMS x 1 bridged output at 4 ohms 1000 watt max and my subs says 12" Subwoofer with dual 4-ohm voice coils 400 watts rms 800 watt max now i have found a wiring diagram.
    http://www.rockfordfosgate.com/rftec...l+-+4+ohms+x+2
    so my ? is with the two subs its a 4 ohm load to the amp now to when i bridge it it will be 500 watts to each cuz its a 1000 watt amp. but i really dont understand how to bridge nor what it does. so will the ohm load match and how do i bridge it? thanks
  9. #99
    RandyJ's Avatar
    RandyJ is offline CarAudio.com Veteran
    Nov 2004
    USA
    4,523
    Your amplifier is 1000w max, not rms. Each sub will see 250wrms if you wire it properly.
    And the way you bridge will depend upon the directions of the amplifier manufacturer. Look into it.
  10. #100
    BigSquid10's Avatar
    Jul 2005
    Delaware
    37
    so what if u have a dual 2 ohm sub and a mono amp that is stable for 2 ohm and i want it to be 2 ohm the diagrams show a total of 1 ohm and then 4 ohm loads so if i want the amp to have a 2 ohm load then would i buy a 4 ohm speaker that will equall 2 ohm to the amp? i thought u had to match the ohms up and the lower ohms the more bass u will get. so then what combo should i do?
    ps> im getting 1 sub and a mono amp.
  11. #101
    IronCityGuy's Avatar
    IronCityGuy is offline Member
    Jun 2005
    East Coast
    38
    Call me an idiot but I need unconfused.
    Running (2) Dual voice coil 2 ohm subs with 2 ohm wiring options will approximately double the rms power of the amp (If the amp can do that) but do the subs share the power or will each one receive the max output.
    EX. A 375Wx1 rms amp @ 4 ohm runs 750Wx1 rms @ 2 ohm. When @ the 2 ohm level will each speaker get 750W or share it and get 375W each.
    Thanks in advance
    JC
    2006 Nissan Altima 3.5SE 5-Speed
    HU: Premier P8MP w/Bluetooth
    F Stage: Rainbow
    Sub: RE SE 12"
    Amps: JL/4/1
    Dampening: Dynomat Xtreme
    Wire: KnuKonceptz
    Car Alarm: .45&SST
    A genius always presents himself as a fool
  12. #102
    Raisedin305's Avatar
    Raisedin305 is offline Banned
    Aug 2005
    Miami,FL
    24
    4,839
    How could I wire two DVC 1 subs? What ohm load would I get wiring it in series?
  13. #103
    gansan's Avatar
    gansan is offline Senior VIP Member
    Apr 2005
    LA,CA
    295
    can u do 2 4ohm dvc = 2ohm load??
    refs: flakko,whites97
  14. #104
    Oct 2004
    28
    5,019
    Quote Originally Posted by gansan
    no
    1 or 4 ohm.
    1 dvc 4 will=2ohm load.
    or 2 dvc 2s.
    2003 Chevy Cavalier
  15. #105
    Oct 2004
    28
    5,019
    Quote Originally Posted by IronCityGuy
    Thanks in advance
    they will split the rms power each.
    2003 Chevy Cavalier
+ Reply to Thread
