+ Reply to Thread
Page 6 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 76 to 90 of 242
Reload Thread: voicecoil wiring options
  1. #76
    Acidburn's Avatar
    Acidburn is offline Super Mod-like-guy
    Dec 2003
    Tempe, AZ
    30
    15,596
    22
    Re: voicecoil wiring options
    to 2 ohms (if you have one amp)
    MdOiDcEtRaAtToOrR
    1996 Chevrolet Impala SS 14.5 @ 94
    1967 Chevrolet Camaro 18.4 @ 74
  2. #77
    BoNkA's Avatar
    BoNkA is offline Member
    Jan 2005
    PA
    31
    75
    I have two quick questions. What's the smallest gauge wire I can get away with for my 15" Brahma (terminal to 1st +/- then to 2nd +/-). Second, should it just be one wire run from the terminal, through the first positives and negatives to the second set, or should it be one wire from the terminal to the first set, then another wire from the 1st to 2nd set? Thanks for any info.
  3. #78
    DoubleOB's Avatar
    DoubleOB is offline 4R05
    Jul 2005
    CA
    32
    Any one can post how to wire this amp to 2 subs for max power??
    Audiobahn A4801T 4-channel amp and two AW1206T 12" subwoofers
    A4801T 4-channel amplifier
    150 watts RMS x 4 at 4 ohms (250 watts RMS x 4 at 2 ohms)
    500 watts RMS x 2 at 4 ohms (4-ohm stable in bridged mode)
    AW1206T subwoofers (pair)
    dual 4-ohm voice coils
    frequency response: 20-500 Hz
    power handling (each): 50-1100 watts RMS (2200 watts peak power)
  4. #79
    damanTO81's Avatar
    damanTO81 is offline Senior VIP Member
    May 2005
    marrero, louisiana
    32
    248
    what are my options on wirering a quad 1 ohm woofer pm me as of now i have them ran on two amps that put out 750 by 2 @ 1 ohm stereo i have each coil ran seperate but the problem with this is both amps must be set exactly the same or it will cause problems so i was wondering what other options i have because i dont have the equipment to set them as exact as they need to be pm me any input thanks
    O8 Titan Crew Cab
    HU:EclipseCD5000
    Sub:Eclipse SW9152Pro
    Amps:Power Acoustik LFA1-5500D
  5. #80
    scutzi128's Avatar
    scutzi128 is offline Member
    May 2005
    Pennsylvania
    57
    Is there any way to wire 1 sub with dvc @ 4ohms each at 4ohms?
  6. #81
    Acidburn's Avatar
    Dec 2003
    Tempe, AZ
    30
    15,596
    22
    no
    MdOiDcEtRaAtToOrR
  7. #82
    fbplaya02's Avatar
    fbplaya02 is offline curious/confused
    Aug 2005
    mineral springs, AR
    30
    26
    i wish i would of saw this 5 minutes ago
  8. #83
    killerCarlo's Avatar
    killerCarlo is offline Junior Member
    Sep 2005
    Little Rock AR
    31
    Q: how can i wire 4 2ohm DVCs to get 1 ohm?? i have 2 crossfire Ps and i want to run them at 1 ohm for my the BMF 1000 i'm about to buy. otherwise i'll have to run them at 2 ohms and then i could get more power at Best Buy.
  9. #84
    fozzymuphet's Avatar
    fozzymuphet is offline Senior VIP Member
    Jun 2005
    Olympia, WA
    183
    Sub 15inch RF HX2:
    Voice coils 2-2ohms at 500 w each
    If i have an amp that puts out 1000w at 2 ohms is it possible wo wire my sub so it gets the 500w per channel? at 2 ohm?
    Also how do i wire it for 1 ohm?
  10. #85
    bdawson72's Avatar
    bdawson72 is offline Finally Has Bass Again
    Nov 2005
    434/804, Virginia 15's:Yezzir
    28
    17,561
    8 Post(s)
    2 Infinity 10 DVQ...........Dual Voice coils.....300 watts rms....How do u wire this with a mono amp
    [email protected] hz(headrest)......Dammit i needs to be louder
  11. #86
    Nikuk's Avatar
    Nikuk is offline Been Gone Too Long
    Jul 2004
    Buffalo, NY
    36
    7,854
    1 Post(s)
    wire all the + coils to an ignition source.
    wire 2 of the - coils to the batt + post
    wire 2 of the - coils to any bolt of screw on the chassis
    and wire the last 2 - coils to the remote wire from the HU.
    don't believe me? Check the sticky.
    What the f00k happened to this place?
  12. #87
    Fordfool302's Avatar
    Fordfool302 is offline Member
    Jul 2004
    Asheville,NC
    33
    85
    Thanks alot for the info, I have a questions about the (1) 4 ohm dvc speaker = 2 ohm load. Ok bear with me I drew this up and scanned it on to my computer but couldn't figure out how to insert on this thread so I'll do my best. in your picture it tells you to put from your speaker output on your amp the + to one voice coil and the - to the other voice coil. would it matter if you put the + and - just on one voice coil or does it have to be exactly like the picture.
    Thanks alot I hope someone can help me!
  13. #88
    jallen28145's Avatar
    jallen28145 is offline Junior Member
    Feb 2006
    charlotte, nc
    Hey guys I have a question. I have 2 JL 10w3's, they are both DVC but one is 2 ohm and the other is 4 ohm. How can I wire these up to a sony xplod 1200 amp. The amp specs are :
    200 watts RMS x 2 @ 4 ohms
    250 watts RMS x 2 @ 2 ohms
    500 watts RMS x 1 @ 4 ohm
    Is this amp ok for these subs? Please help me figure this out!!! THANKS!
  14. #89
    babyken937's Avatar
    babyken937 is offline Junior Member
    Jan 2006
    springfield
    22
    hey guys i hit a 140db and my dad told me 0 wire i would hit harder is that true
  15. #90
    babyken937's Avatar
    Jan 2006
    springfield
    22
    Quote Originally Posted by jallen28145
    well y dont u wire the 4 ohm to 2 and match them i had a premium sound sony amp and it killed tghe hell out of some wo's so ya that will pound buddy
+ Reply to Thread
