+ Reply to Thread
Page 17 of 17 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
Results 241 to 250 of 250
Reload Thread: voicecoil wiring options
  1. #241
    MikeCTM2's Avatar
    MikeCTM2 is offline Junior Member
    Nov 2002
    chino, california
    Re: voicecoil wiring options
    I'm glad i have the rockfordfosgate website bookmarked.
    Yes, this Thread is now useless. No Need to have as a sticky......
  2. #242
    williamhowell82's Avatar
    williamhowell82 is offline Junior Member
    Oct 2016
    Lincoln,ne
    Twisted sounds 1.8 kilowatt what should I run my dual voice coil tuome sub suggest positive negative on speaker or one voice coil on speaker and one voice coil and speaker B where are they truly connected as in they should be in a monoblock just wondering if it says speaker and speaker B makes it sound like they are separate
  3. #243
    kdc_619's Avatar
    kdc_619 is offline Member
    Jan 2012
    Fort Hood Texas
    37
    22 Post(s)
    I just bought a pair of FI Alpha 12's. They're single 2 ohm. As with most sub amps..my RF 1200 has one channel with 2 + outputs and 2 - outputs. To get a one ohm load can I use both + outputs to both subs and both - or will I have to use one + output and run a wire from the positive on 1 sub to the positive on the other?
  4. #244
    williamduc's Avatar
    williamduc is offline Junior Member
    Nov 2017
    US
    1 Post(s)
    Quote Originally Posted by kdc_619 View Post
    I am so confused. I think I screwed up.
    I bought two Kenwood mono amps kac-501 to push two punch dvc 4 ohm 10 shallow mounts
    My thoughts were the amps are 300 watts rms at 4 ohms so I should purchase subs that are 300 watts rms 4 ohms.
    But after reading this big *** thread it looks like I should have purchased the punch shallow dvc 2 ohm 10s to pair with the 4 ohm amps.
    I think it will still work because the amp handles 2 ohms at 500 watts. But am I making it work too hard? Or are two amps too much?
    So confused.
    Sent from my Pixel XL using Tapatalk
  5. #245
    williamduc's Avatar
    Nov 2017
    US
    1 Post(s)
    Quote Originally Posted by williamduc View Post
    So confused.
    Can someone answer one question for me.
    If the amp specs are 300 watts rms at 4 ohms and 500 watts rms at 2 ohms would it not be better to buy a 2 ohm dual voice coil sub or a 4 ohm?
    True or false!?
    A 4 ohm dvc 10 inch sub rated 300 watts rms paired to a 500 watt @ 2 ohm amp is less powerful by 50 rms watts (4 ohm) than a 2 ohm dvc 10 inch sub rated at 300 watts rms paired to a 300 watts rms at 4 ohm amp.
  6. #246
    williamduc's Avatar
    Nov 2017
    US
    1 Post(s)
    True or false!?
    I think I understand now.
    The more watts, the louder the sub no matter what ohm it is at.
    So getting the dvc 4 ohm sub allows me to use the amp to it's full potential of 500 watts by wiring it in parallel. (Brings it to 2 ohms)
    Had I purchased the 2 ohm dvc sub, I would only be using 300 watts, which would have been ok too since the subs are rated at 300 watts rms, 600 max. The amp would definitely stay cooler and the sub would never be pushed too hard.
    Right?
  7. #247
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,257
    41 Post(s)
    6035 Post(s)
    Right?
    Not true since a lot of amps put out most power in 1 ohm and 1/2 ohm.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
  8. #248
    williamduc's Avatar
    Nov 2017
    US
    1 Post(s)
    Wtf are you talking about? My amp cannot handle 1 ohm. It would have been nice to get some sort of confirmation that I wired it right but it seems more important to correct a statement that doesn't contribute or help in any way.
  9. #249
    smichael85's Avatar
    smichael85 is offline Junior Member
    Feb 2018
    Richland, WA
    21
    11 Post(s)
    Check out this article for help with subwoofer wiring.
    https://mobileinstallguide.com/subwoofer-wiring-guide/
  10. #250
    Mariusi's Avatar
    Mariusi is offline Junior Member
    Apr 2018
    Tiran
    1 Post(s)
    yeah nice one matt
+ Reply to Thread
