Click "Reload" to fetch new posts without leaving the page.
Automatic thread refreshing has been stopped because you appear to be idle. Un-Idle
Reload -
Re: voicecoil wiring options
I have a DVC 2ohm subwoofer, and want to wire it to a 4ohm load to a two channel pa2300, bridged. I'm guessing that I hook the driver up + -> -, and then + to one channel output, and the negative to the other channel output. Am I correct?
i got a pretty simple question for anyone, just because i confused myself a little and got screwed on the equipment i ordered.... first ill start with.. i have A pioneer gm-d8500 d-mono 1200w amp and ordered 2-12" subs for that amp.. but the subs were on back order and i got an "equal replacement" sub that i was told will work perfect with my amp. it was the pioneer ws-309s4 1400w.. when i recieved the order and installed the subs i found out real quick the amp was severly underpowered and now i need a larger amp but im looking into a 2-4 channel bridgeable amp.. my question is if i have a 4ohm svc sub and wire it to 2 or 1 ohm will it damage the sub, and with the subs wired together do i double the reccomended rms and peak wattage required for the sub.. thanks for any help
aw crap I was excited to see this but the images are not working anymore
sad day
2001 Jeep Grand Cherokee Limited
Mach 5 ixl 18.4
7 cubes tuned to 34hz
Hifonics Brutus 2k
Knu Wires
Originally Posted by
Bassin Buick
Why?? You still haven't learned to eat my balls in the WTEMB section.
You save lives. *bookmarked
Oh haha, I already have that page bookmarked. I use it a lot. I was looking for a site that will do up to 6 subs at least but Ill google it myself :P thanks for the help though. Much appreciated.
im pretty sure this worthless thread doesnt need to be stickied anymore...just say'n
AZ_G6GT_Beatin
then your a D U M B A S S can you read that shi t
misfit138
How did you manage to pack that much stupid into such a small amount of words?
Sold to: nom nom, Trever, Spooney, dkhage1, tghersh88
Bought from: MikeyF, Paaco1981, Thorshammer1, Sundownz, Ridinhi, Cl1ckclack, nom nom, profoundwill, vfrrider, El_Weenie, DBBOOM
What are my options for a dual 1.4 ohm voice coil?
2.8 or .7?
- You may not post new threads
- You may post replies
- You may post attachments
- You may edit your posts
Forum Rules
Bookmarks
