Results 1 to 6 of 6
Reload Thread: Where Do i put my Ground In a Chevy Corsica
    bigdaddy_87_200's Avatar
    bigdaddy_87_200 is offline Junior Member
    May 2003
    Indianapolis
    26
    Icon32 Where Do i put my Ground In a Chevy Corsica
    When i put my face on my cd player and the volume is on 0 i can here a noise like thunder in my speakers do i have a bad ground.
    George Grady
    Jacobs's Avatar
    Jacobs is offline JIMMY GO BOOM BOOM
    May 2002
    Kingsville, Ont. Canada
    29
    253
    I don't think that would be a bad ground. You could have a wire crossed or something though. If it was a bad ground the deck just wouldn't turn on
    Loud music is good... Loud music that is clear is better
    ______________________________
    2002 GMC Jimmy
    hu - pioneer primer DEH-P630
    Sub amp-JLaudio 500/1
    Speaker Amp-Pioneer GM-X564
    subs-pioneer Primer TS-W1241DVC
    6X9's-Pioneer TS-A6985
    pioneer primer TS-C504 component speakers
    May 2003
    Indianapolis
    26
    Icon32 where could a wire be crossed
    where could a wire be crossed at. im sure that there aint know wire crossed on my amplifier or be it be on the speaker or on the back of the cd player
    George Grady
    Jacobs's Avatar
    May 2002
    29
    253
    Could be on the back of the deck, or it might be an engine whine going through your speakers... All the speakers are amped im assuming?? If so make sure the battery wire is running down the speerate side of the car, and they don't come close to eachother..
    2002 GMC Jimmy
    MXJMR's Avatar
    MXJMR is offline Senior VIP Member
    May 2003
    Naptown, IN, US of A
    212
    ur taking to much juice from ur battery and its makin ur alternator hum in ur speakers, u may want to try to run a seperate battery just for ur amp,subs etc. and stuff, unless u already have done that
    junocdx's Avatar
    junocdx is offline Senior VIP Member
    Jan 2003
    AR
    26
    227
    I'm guessing its a new deck, so check your gains on your amps. I had that problem when I installed my stuff. Make sure your gain matches your preamp out voltage.
