Results 1 to 5 of 5
Reload Thread: 4 channel amp - 2 subs!!!!!!
    Unregistered's Avatar
    Unregistered Guest
    I Never knew how different a 4 channel is to hook up. Yes I'm a rookie. But I love this hobby. What can I say.
    Anyway this SALESMAN at the car audio shop told me I need two RCA's running from the deck with a Y-adapter. Then I went to another shop (to buy a Y-adapter) and he said I only need one. ---Thats my first dumb question.
    I've tried both, but receive no sound.
    So I guess my second dumb question is, do I need to brige wire the subs to the amp or parallel?
    gregj9's Avatar
    gregj9 is offline Member
    Jan 2002
    florida
    44
    136
    If you aren't getting any sound there should be an Input switch on the amp somewhere. you will need to switch to which ever inputs you are using if only one it will probably say something like input for channels 123&4. If you use two sets it will say something like Input for channels 1&2 and 3&4.....if you use only one and your deck only has one set of rca outs on it you will lose your fader if the amp is for the mids and highs.....
    96 honda passport
    eclipse head (55040)<br />jl audio 500/5<br />Infinity kappa separates up front<br />4 eclipse 10"<br />audio control esp2 center stage processor
    soon to come: Eclipse mids and highs upgrade<br />e-comm module<br />nav system
    Unregistered Guest
    I wish there was a switch to change channels on the amp - but I don't have one on this amp. Any other suggestions?
    SuckMikeHawk23's Avatar
    SuckMikeHawk23 is offline #1 Laker Hater
    Jan 2002
    626 California
    702
    if u only have 1 sub, then u only need 1 rca. check all the settings on ur amp... gains, crossovers... and make sure ur getting power, and everything is connected right. make sure the ground is solid, and the fuse up front isnt blown.
    Team Caraudio.com
    2000 Honda Civic Coupe:
    Alpine CDA-7892
    MTX81000D
    US Acoustics USX4085
    Crystal Mobilesound CPE60S
    Crystal Mobilesound CSC60S
    2 E12KD2's
    4.7 cubic foot ported box
    AIM: TeamVicious23 and FishermanSteve23
    Unregistered Guest
    I have TWO subs - and yes red light at amp - (all power is there). And the amp (Pyramid 4 channel 400watt) is properly grounded. My main guess is that the subs (2 8ohm MTX 4000) are not wired correctly to the amp?
  1. WTB or Trade 4----4 channel amp & Budget subs
    By xhilr8n in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 03-01-2008, 12:58 PM
  2. WTT: 5 channel amp and subs for similar
    By the_franchise in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 10-27-2007, 09:02 AM
  3. Replies: 9
    Last Post: 05-08-2002, 06:08 PM
  4. channel amp or subs first
    By shorty24sev in forum General Discussion
    Last Post: 04-09-2002, 03:35 PM
  5. Wiring of dvc subs and 2 channel amp
    By Snapnakk in forum Subwoofers
    Last Post: 03-12-2002, 03:22 PM
