Results 1 to 5 of 5
Reload Thread: 1999 oldmobile intrigue radio removal
    jco1385's Avatar
    jco1385 is offline expert jcologist
    Sep 2007
    Mobile, AL
    18,860
    4 Post(s)
    644 Post(s)
    How do i get the factory radio out of this car? Its not my car, but i will be putting an aftermarket radio in one this afternoon. i have no clue if there are and special tools or tricks to do this. if you can help, please chime in! thanks
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    Pioneer 6x8 3-ways (rear)
    JVC CH-X1500 12-disc MP3 Changer
    Alpine Type X 12" 2 cubes @ 30hz
    MTX 404 runs the inside
    MTX 1501d runs the X
    Optima G75/25 RT up front
    2x Optima G31 YT in the trunk
    200a EA HO Alt (1/0 Big 3)
    ALL MY WIRE IS WELDING CABLE
    Quote Originally Posted by Johnny Drama View Post
    I always knew I was a feggot.
    Quote Originally Posted by Rashaddd View Post
    We're all feggots on the inside
    Quote Originally Posted by ToledoTom View Post
    I am sure the administration will be having a few words with you when they catch wind of your language.
    DO NOT SEND ME ANYTHING USING UPS. I WILL NOT DEAL WITH THEM EVER AGAIN
    OFFICIAL FEEDBACK THREAD
    lilmaniac2's Avatar
    lilmaniac2 is offline Ask Me about SI Mag V4!
    Jan 2006
    Somewhere, Else
    30
    15,930
    Re: 1999 oldmobile intrigue radio removal
    In the alero I know you have to take off the gear shift knob ( there is a clip on the front of it that you just pull out for an automatic ) then you pop the trim panel off for the gear selector.
    next you pull the hvac and the radio trim as one piece.
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,860
    4 Post(s)
    644 Post(s)
    any screws in the radio trim piece, or just clips? any crazy *** tool to get the radio out. my factory radio in my t-bird had special clips that are a ***** to get to work
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,860
    4 Post(s)
    644 Post(s)
    bump.
    gonna be doing this in about an hour
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
    jco1385's Avatar
    Sep 2007
    Mobile, AL
    18,860
    4 Post(s)
    644 Post(s)
    ok, in case anyone ever searches for this one day...
    no need to remove the shifter. push down the e-brake and put it in neutral. open the arm rest and remove the 2 screws at the front. lift up the part with the cup holders (there are about 4 clips holding this down). next pull straight out at the bottom of the radio trim piece. you will have to pull pretty firmly, but don't break the clips. then there are 3 phillips screws holding the stock radio. unscrew and pull out the radio. Unclip the harness, pull the antenna wire out and you're done.
    1994 Thunderbird
    JVC KD-AV7010
    Alpine 6x9 3-ways
