Results 1 to 4 of 4
Reload Thread: 5 pin din older fosgate
    Mar 2003
    Preston Ct.
    86
    Does anyone know the pin out on older fosgate pr-2100. The pr-2100 uses 5 pin din interconnects. also is there an adaptor that could adapt to rca's. I would like to use this amp in my system to maybe run a set of comps. Please anyone point me in the right direction. Thanks CC
    evo2k3's Avatar
    evo2k3 is offline Senior Bizznitch
    Dec 2002
    Chicago
    1,057
    Re: 5 pin din older fosgate
    I used the adapter because my stock mitsu system used it....I picked it up at auto toys.com, but I am selling it now, its like 25 bucks there, I will ship it out to you for 18ish if you want (it converts the din cable into 2 sets (4 plugs total) of rca's plus a remot turn on.
    I'm back to stock in my new car.....
    Cosmic Charlie's Avatar
    Cosmic Charlie is offline Member
    Mar 2003
    Preston Ct.
    86
    Hey evo2k3, thanks for the reply, but I think I need 2 plug adaptor, because the pr-2100 is 2 ch and has a seperate remote power wire. But I'm not totally sure, I was hoping an old timer might remember this model and maybe help me out. Thanks again for your reply if I find out that what you have would work I'll try to get ahold of you CC
    evo2k3's Avatar
    Dec 2002
    Chicago
    1,057
    its still a 5 pin din though, you would just not use two of the rca outs and the remote.....the adapter is intended for a different use, but from what it sounds like it would run fine. keep in touch
