Results 1 to 6 of 6
Reload Thread: Will this set up work?
    Afboy143's Avatar
    Afboy143 is offline aka Bumpin Expo
    Nov 2002
    Tampa, Fl
    384
    I have 2 600 watt El1500 Bazooka mono amps. I also have 2 SVC 4 OHM subwoofers. Is there ne way i can wire this set up to make it sound better than 1 amp running both subs or what
    1x Stereo Integrity 15" Mag
    1x Hifonics 1500.1D
    1x Hifonics 420.2
    4x Infinity Reference 6x8
    1x Pioneer 8600
    MikeofTulsa's Avatar
    MikeofTulsa is offline The one and Only!
    Feb 2002
    Tulsa, OK
    21,235
    1 Post(s)
    308 Post(s)
    well u could use both amps...but the gain settings would have to be EXACTLY the same........but i'd jus get one decent amp and wire both subs to it....ps bazooka isnt all that great....amps are very overated.....
    paikiah's Avatar
    paikiah is offline Wangaholic
    Nov 2002
    Seoul, Korea
    40
    7,770
    46
    1 Post(s)
    Re: Will this set up work?
    or you could get one amp to run one sub each.
    Team Caraudio
    Sony C90, 210 EQ
    Seas 27TDF/C, RE XXX 6.5, custom xo (dyn 240GT sitting idle)
    RF 60.2 amp
    eD A15.22
    Soundstream picasso 1400.1D
    Bass drive-by's are uncool.
    Afboy143's Avatar
    Nov 2002
    Tampa, Fl
    384
    Well i have 2 Bazooka EL 1500 Amps. I dont really have ne money for a better amp so i need to do with what i got now. Is there ne way i can use these amps to run the subs ne better.
    1x Hifonics 1500.1D
    1x Hifonics 420.2
    1x Pioneer 8600
    Afboy143's Avatar
    Nov 2002
    Tampa, Fl
    384
    Is there ne way i can trick the wiring to make the 2 amps push the 2 subs for 1 ohm each that way each sub gets about 500 instead of 250? (If ne of this is wrong tell me cuz im not good at this ohm stuff)
    1x Hifonics 1500.1D
    1x Hifonics 420.2
    1x Pioneer 8600
    junocdx's Avatar
    junocdx is offline Senior VIP Member
    Jan 2003
    AR
    31
    227
    With a SVC 4, there is no way you can make that into a 1ohm. Any way you set it up, it really wont sound "better"
    This is just my opinion. Other people might have it different... If your vehicle can handle the power output to run both amps at the same time, then run one sub per amp. Just run each sub straight to the amp for a 4 ohm load, and you'll get 350RMS to each sub. That would probably be your best option. If not, then wire the subs in parallel and run it to the amp for a 2 ohm load, and get 500RMS
    People will say stuff about Bazooka being crappy. I agree they are overrated, but dont worry about it. The amps work (I'm assuming), and if it makes you happy thats all you really need.
    Hope that helps.
