Results 1 to 2 of 2
Reload Thread: 4 gauge to 8 gauge.. will it be enough?
    Troydb's Avatar
    Troydb is offline Member
    Nov 2007
    Down South
    113
    I plan on running 4 gauge wire to my distribution block (about 14 feet) and then run 8 gauge power and grounds to my amps. The 8 gauge will be about 4 feet. The amps are a Monitor 1 and Arc 400.2
    Will this be large enough gauge wire or should I go with something else? I feel like the 4 gauge will be fine, but I am not sure about running 8 gauge to the amps.. any thoughts???
    luvinthebass's Avatar
    luvinthebass is offline CarAudio.com Elite
    Dec 2004
    Middle of Iowa
    28
    10,447
    Re: 4 gauge to 8 gauge.. will it be enough?
    you should be fine.
