Results 1 to 13 of 13
Reload Thread: Help
    Hawaiian's Avatar
    Hawaiian is offline Senior VIP Member
    Feb 2003
    CA
    160
    Help
    Hey,
    I was all stoked on my new kicker 1200.1 which I will be having power my 15" Adire audio Brahma (Dual 2 ohm VC wired parallel to 1 ohm). Got it all wired up by a guy who worked for a car audio company who is a friend of mine, and turned it on, worked perfectly. Kept it low so i could break everything in and not push to hard at first. Turned it off for a bit, came back and turned it on and nothing. When I turn on the power I get a flash of the Red protect light, and then it dims out to no lights at all. The only troubleshooting things in my manual talk about red or green constant on, no single on the fading. I am wondering what this light means, I personally took everything apart to make sure that all the wires are run properly. Ground, Power and remote are all working, not totally sure how to check RCA's but they are brand new. Any idea what is going on?
    Hawaiian's Avatar
    Feb 2003
    CA
    160
    As part of this same question, when wiring in parallel, does it matter which positive or negative the speaker wire from the amp is wired to? I drew a pic but its too big or something and i don't know how to link pics. Anyway i have the positive from the amp running to the positive on one voice coil then another to the other positive, then on the other voice coil i got the negative running from the amp and then a wire running to the other negative (the one next to the positive with the wire from the amp)
    ricerdude's Avatar
    ricerdude is offline TEAM THRESHOLD
    Dec 2002
    Idaho Falls, ID
    32
    687
    you might have blown your amp?? i dont know ..are you sure you checked your connections...double check them...un hook the sub and turn the amp on and if it does the same then take the fuse out of the amp power..and let it sit for a while..them try again...if either of those dont do anything you amp is shot..
    D
    1991 Mitsubishi Eclipse gsx
    far from stock
    Pioneer Premier deh-p630
    Pioneer 3 way 5.25
    Pioneer 6x9s--soon to change
    Rockford Fosgate Power bd1000.1
    1 Orion XTR 12 series 2 in 2.9 cuft. ported evclosure, tuned to 37hz..
    proud member of TEAM THRESHOLD
    Hawaiian's Avatar
    Feb 2003
    CA
    160
    ************************************************** ************************************************** ****************MUTHER**************************** ************************************************** ************************************************** ************************************************** ************************************************** ****IN******************************************** ************************************************** ************************************************** ********************PIECEOFSHIT******************* ************************************************** *******
    thanks, i just got it so i guess i can send it back if i have to...
    ChefJoe's Avatar
    ChefJoe is offline Senior VIP Member
    Dec 2002
    Columbus, OH
    38
    267
    On a mono amp, it shouldn't matter. The dual sets of terminals are usually fused at the amp itself. I go with the "**** be broken" diagnosis if all the wires are correct.
    97 VW Jetta - building a system from parts in my old 85 Jetta
    HU: Pioneer P740MP with 12 disc changer
    Front: 3.5" JBL GTO302s in dash
    5.25" Cerwin Vega Vega Series 502s in door
    Amped: US Acoustics USX-2050 @ 2 ohm
    Rear: Stock components
    Sub: Single 12" Vega 124 in a cheap bandpass box
    Sub Amp:US Acoustics USX-2150 bridged
    ricerdude's Avatar
    Dec 2002
    Idaho Falls, ID
    32
    687
    i like that "**** be broken" thats a good one...lol...
    D
    far from stock
    Pioneer 3 way 5.25
    Hawaiian's Avatar
    Feb 2003
    CA
    160
    no, not right now it isnt. only if its some else's stuff
    ricerdude's Avatar
    Dec 2002
    Idaho Falls, ID
    32
    687
    no i said i like the saying...but that fukin ***** dude...you said you drew a diagram...well go into paint..or what ever you have and redraw it and go to image on the pull down menu and go to attributes and tell me what he resolution and size of the pic is...
    D
    far from stock
    Pioneer 3 way 5.25
  9. #9
    Hawaiian's Avatar
    Feb 2003
    CA
    160
    Doesn't really matter about my pic anymore i guess, just got back from rewiring my sub into series, and it still doesnt work, exact same reaction by the protection light. Evidently its not a problem with resistance.
  10. #10
    Apr 2002
    Idaho Falls
    40
    1,134
    See if you can try your amp in one of your buddies cars!! Then you can be sure that the amp is the problem and not something in your car
    '99 Ram Sport Quad cab
    Alpine 7897
    Rainbow 6.5 comp. set
    180 amp Iraqqi alt
    Optima yellow top
  11. #11
    Hawaiian's Avatar
    Feb 2003
    CA
    160
    k, just figure i might wait till tomorrow. Don't really think they wanna try it at 1130. I would just be worried that something of their would break and they would blame it on me. I don't have any real good friends with sounds around here, just a couple guys i know.
  12. #12
    Apr 2002
    Idaho Falls
    40
    1,134
    Take a road trip to Idaho We'll try it in my truck But I don't see how it could hurt anything in a differant car so I wouldn't be worried about that. Prolly the worst it could do is pop a fuse which is no biggie
    Alpine 7897
    180 amp Iraqqi alt
    Optima yellow top
  13. #13
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    stupid question, but did u check ur inline fuse? check ur ground n make sure it's fine. u just gotta check all the small details. u can just take ur amp n put into someone els'es car, n viceversa.
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
