Results 1 to 13 of 13
Reload Thread: the the crap??
    nick3470's Avatar
    nick3470 is offline Ballin' on a Budget
    Jul 2002
    Ames, IA
    686
    what the crap??
    ok i have a power acoustic ov2-820 and a kicker solo 10 l5
    how could i wire this up the best???
    the amps ratings are
    180rms x2 @ 4 ohms
    230rms x2 @ 2 ohms
    460rms x1 mono
    820max x1
    the sub is
    900w max
    450w rms(225 per voice coil)
    how could i wire these to get the best results, without hurting either component?
    nswartley's Avatar
    nswartley is offline Down and out...
    Nov 2002
    (Near) San Jose, CA
    31
    5,879
    whats the impedance of the subwoofer coils?
    nick3470's Avatar
    Jul 2002
    Ames, IA
    686
    dual 4 ohm coils or dual 2, whichever would be better(i havent bought the woofer yet)
    which would work better for this?
    ricerdude's Avatar
    ricerdude is offline TEAM THRESHOLD
    Dec 2002
    Idaho Falls, ID
    32
    687
    if the amp is rated at one ohm than do the dual 2 ohm ....and parallel the sub..that is one ohm it will bump..
    D
    1991 Mitsubishi Eclipse gsx
    far from stock
    Pioneer Premier deh-p630
    Pioneer 3 way 5.25
    Pioneer 6x9s--soon to change
    Rockford Fosgate Power bd1000.1
    1 Orion XTR 12 series 2 in 2.9 cuft. ported evclosure, tuned to 37hz..
    proud member of TEAM THRESHOLD
    nswartley's Avatar
    Nov 2002
    (Near) San Jose, CA
    31
    5,879
    yea, so if your amp is 1 ohm stable then get the DVC 2 ohm....if its only 2ohm stable then get the DVC 4 ohm
    nick3470's Avatar
    Jul 2002
    Ames, IA
    686
    its 2 ohm
    so bridge the amp, and run both positive coils together(same with negative)
    tommyk90's Avatar
    tommyk90 is offline THE WHOLE THING!!!
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    Originally posted by nick3470
    its 2 ohm
    Is the 460x1 rating at 4 ohms or 2 ohms? Seems to me like it would be at 4 ohms seeing as most 2 channel amps aren't 2 ohm bridged stable. In that case you would get the dual 2-ohm version and wire the coils in series. You only have one sub correct?
    Team Kicker (R.I.P.)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
    2008 Bassrace 130-139.9 Regional and National Champion
    2006, 2007, 2009, 2010, 2012 and 2013 MECA Champion (S1, SR1, DB1, S2, S3, S4, S5)
    One DD 9510 powered by two Sundown SAZ-2500's
    Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
    Kicker wiring throughout.
    nick3470's Avatar
    Jul 2002
    Ames, IA
    686
    yeah only one sub(so far)
  9. #9
    nick3470's Avatar
    Jul 2002
    Ames, IA
    686
    couldent i get the dual 4 ohm and wire them in parrallel?
  10. #10
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    Well, since it looks like that amp's power is 460x1 @4 ohms. So you have to get the dual 2-ohm and wire the sub in series. That way the amp sees a 4 ohm bridged load.
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
  11. #11
    nick3470's Avatar
    Jul 2002
    Ames, IA
    686
    ok thanks
  12. #12
    nswartley's Avatar
    Nov 2002
    (Near) San Jose, CA
    31
    5,879
    youll only get 360watts total at 4 ohms. are you going to be getting 2 subs? 1?
  13. #13
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    He said it's 460 at 4 ohms. And yeah, he's only getting one sub.
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
