Results 1 to 2 of 2
Reload Thread: ? for those using Walmart amp install kit
    1meanZ's Avatar
    1meanZ is offline Junior Member
    Mar 2003
    NW, Indiana
    44
    20
    http://www.walmart.com/catalog/produ...3A3947%3A96490
    You know, the $24 one. I noticed it comes with an 8 gauge ground wire. Will that be OK to use with the 4 gauge power wire or should I just buy a couple feet of 4 gauge ground wire separate? It will be used with a Kicker 550.3 amp. Thanks
    evo2k3's Avatar
    evo2k3 is offline Senior Bizznitch
    Dec 2002
    Chicago
    1,057
    Re: ? for those using Walmart amp install kit
    the reason they do that is because the reistance in 20 feet of 4 gauge is pretty similar to that of 4 feet of 8 gauge.....with that said, I would still recomend just buying the same size because it will lessen the resistance of the wire.
    I'm back to stock in my new car.....
