Results 1 to 5 of 5
Reload Thread: amplifier qusetion please help
    chris2's Avatar
    chris2 is offline Junior Member
    Mar 2003
    mobile
    i previously had a 2000 ford mustang convertible with 4 5x7s and they were running off a 2 channel amp i have. well i traded the mustang in for a jeep cherokee, and i have two tweeters, two mb quart 6x9s, and a 6and a half component system running off the factory amp and cd player i bought. well why cant i use this 2 channel amp to deliver some extra power to my mids and highs? just wondering cause i was told u could run like 4-6 subs off a mono amp
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    36
    8,477
    32
    Not sure exactly what youre asking....what exactly do you want to power with the 2 channel amp?
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    39
    2,609
    29
    2 Post(s)
    A little more info. on the amp and the speakers you want to wire up would be most helpful.
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    if i got wat u said, u need to "bypass" the factory amp i believe. once you bypass it you cna hook ur aftermarket amp. you gotta disconnect the connections i believe, but someone should help u here, i haven't had the need to bypass my factory amp, if there is, yet
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
    i3abyjay25's Avatar
    i3abyjay25 is offline Get F'n Loud
    Aug 2002
    Dallas, Georgia
    38
    2,128
    1 Post(s)
    i know in my sable,, when i installed an aftermarket HU, i had to bypass the factory amp.. and i did it by.. right behind the HU, their was 2 sets of wire harnesses.. 1 was ran w/ the factory amps, and the other set was ran w/o the amp.. just had to swap.
    Fs/t
    Orion 2500d
    Orion 4004
    250 amp alt w. external voltage reg. for a ford explorer
    Refs: Electrodynsmic, Millerboy, Ugaboiii, Ezekiel81923, Toaster, Team Psi, KickerCivic1, MatrxxDude, TommyK90, Xterra02_Pat
