Results 1 to 3 of 3
Reload Thread: How should I wire my Subs
    chingo40's Avatar
    chingo40 is offline Junior Member
    Feb 2003
    West Bend, WI
    32
    27
    I have 2 audiobahn aw1006q subs. They are dual 4 ohm. Sadly I have them in a sealed box. I just need to no the best way to get as much bass as i can out of these. Should I wire them each individually in parralel to their own separate amp, or together to one amp or what. I just need help.
    chingo40's Avatar
    Feb 2003
    West Bend, WI
    32
    27
    Also, can i wire the subs individually and than run them to one amp.
    smacktown's Avatar
    smacktown is offline Junior Member
    Mar 2003
    Arkansas
    30
    i would get a amp that bridges to 1 ohm. if you go with that then you could go with option 1 on this website listed below.
    http://www.rockfordfosgate.com/rftec...=18&image.y=14
    with your subs i would get a audiobahn A2200HCQ amp, it is 1600 watts at 1 ohm
    smacktown
