Results 1 to 12 of 12
Reload Thread: Wiring Help ???
    Jaccrock's Avatar
    Jaccrock is offline Junior Member
    Mar 2003
    Miami, FL
    Icon32 Wiring Help ???
    I have a JBL 600.1 amp, and I am considering getting either an Elemental Designs E12K or an Audiobahn AW1205Q. The audiobahn is a dual 2 ohm, could that handle 600 watts @ 1 ohm? If wired correctly? Or the Elematal I can get in a dual 2 ohm or dual 4 ohm at how many watts can that handle?
    I used to have the JBL 600.1 with a 12" Hollywood Excursion( I want to say max power 1400) but I'm not sure. I just want to get another subwoofer that will sound similar. The Excursion broke b/c of the lead wire being vibrated against by teh sub going in and out. The wires were frayed. I want to make sure this doesn't happen again.
    Any help is greatly appreciated.
    Quinn03's Avatar
    Quinn03 is offline Member
    Mar 2003
    NaDm.Net
    34
    65
    Icon14 check this
    based on how ya asked ya question you cannot increase a sub power range by lowering it's impedance on the amp. Cause the amp only sees a resistor, the sub can care less about 8 ohms, 4 ohms or 1 ohm. the amp cares though. Basically you just want the amp two push the resistant current through the sub at it most effiecient rms. so a dvc is a good idea or multiple subs in parrellel. 300W rms @ 4ohms is on average 600W rms @ 2 ohms. as long as you don't stress the sub for to long it doesn't matter what impedance is used.
    mgaidica's Avatar
    mgaidica is offline CarAudio.com Veteran
    Jan 2003
    Northville, MI
    3,065
    im using a jbl 1200.1 wired 2 ohm to both of my 12" K's, has been working fine....
    2x JBL 1200.1 for sale...
    AIM- Mgaidica
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    Re: check this
    WTF???!!! ok, i know what i am talking about...and u even confused me! jac....don't listen to this kid. to your question....i believe you would be better off with th E12k...or if u want louder like u are talking about...go with the e15k!! But, yes...get the dual4ohm version and the you wire the voice coils in parallel to get a 2ohm load to the amp...and it can handle the 600 watts. Put a e15k in a 2.5-3 cube ported box w/600 watts and watch it pound...and u won't have to worry about the lead either...and they come with 3 year warranties!! nothing in their price range can come newhere near them. peace
    NG
    p.s. if ya need a wiring diagram check
    http://edesignaudio.com/ep/wiring.htm
    then look for 1 dual4ohm and parallel!
    http://crunktimes.com/ct/
    nG - BSEE
    Jaccrock's Avatar
    Mar 2003
    Miami, FL
    still confused
    So was my last sub powered at 300 or 600 watts?
    Quinn03's Avatar
    Mar 2003
    NaDm.Net
    34
    65
    Icon33 yeah disregard the statement by me
    when i first wrote the response i thought you were talking about subwoofers but i looked at it again and I see your're not. MY FAULT!
    Jaccrock's Avatar
    Mar 2003
    Miami, FL
    subs
    I don't want to get a 15" sub b/c i already have a box for a 12". Won't the E12k blow b/c they're only 400 watts and I'd be powering it with 600 ???
    mgaidica's Avatar
    Jan 2003
    Northville, MI
    3,065
    well technically your actually pushing 700 cause the jbl's put out more than they say. if u go to the spec's on the ED k's it says anything up to like 900 rms. You shouldnt blow it, just watch your gains and dont play it for hours on end.
    AIM- Mgaidica
  9. #9
    Jaccrock's Avatar
    Mar 2003
    Miami, FL
    mgaidica
    where is the webpage that says 900 rms?
    and why do they only listed at 400 rms?
    (I'm not asking to be a smart%$$, I'm just new to audio)
    Thanks
  10. #10
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    Re: mgaidica
    Thanks
    ok, 400 watts rms is a VERY conservative rating. i've talked to loyd (ed K guru) and he has said b4 that they can handle more...but it all depends on application also. you just don't want to go outradeously high...i belive 900watts is WAY too much. 6-700 watts is the max they should get for daily driver! u'll be fine with th ~650watts that the jbl puts out at 2ohms! peace
    NG
    nG - BSEE
  11. #11
    mgaidica's Avatar
    Jan 2003
    Northville, MI
    3,065
    http://edesignaudio.com/ep/kts.htm
    scroll down "max. RMS"
    well anyway, yeh, i talked to lloyd about it once 2, he said they'll be fine..
    AIM- Mgaidica
  12. #12
    Jaccrock's Avatar
    Mar 2003
    Miami, FL
    Thanks
    Thanks for the help !
