Results 1 to 7 of 7
Reload Thread: Power and ground from amp, so I only need switched power to head?
    Snail's Avatar
    Snail is offline Junior Member
    Feb 2003
    San Jose, CA
    37
    15
    Icon30 Power and ground from amp, so I only need switched power to head?
    My head unit is an Alpine CDM 7874 and my amp is an Alpine MRP F200.
    I just got back from an audio shop where the guy told me that because my amp is running all four of my speakers (six including the spliced in tweets), the only thing coming off the head is the blue remote turn on wire and the four RCAs. I thought I would have to run a power and ground wire from the head AND the amp. And what about the switched power (ignition) lead? He didn't say anything about that. Does that go from the head to a wire that gets power when the key is in the ACC position like before?
    Would that mean that since the switched power lead is upstream of the source of power (the amp), this setup would always have my amp on, even when I'm walking away from my locked car? Or is that wrong, and all this guy forgot to mention was that the switched power wire needs to be hooked up too?
    And assuming this guy is right (plus the ignition wire bit), where do I put the 15 amp fuse that's attached to the yellow power wire coming out from the head unit harness? The amp will have a 25 amp fuse so I'm thinking the 15 amp one needs to be in there somewhere. Does it go on the remote turn on wire?
    So is this guy nuts or am I ignorant?
    Thanx peeps.
    [email protected]
    black 1993 Toyota MR2 turbo
    Spddracer's Avatar
    Spddracer is offline Sounds Goooooood
    Mar 2002
    Ohio
    50
    1,345
    15
    Are you using the factory harness with the adator that plubs into your car ? You will need power and acc power to the HU
    1990 300ZX Stage IV Twin Turbo
    Pioneer Premier P940MP
    CDT HD 6.5" Comps
    JL 300/4 Active
    (2) PG Ti10d
    Directed 1100d
    "WORK HARD.....
    PEOPLE ON WELFARE DEPEND ON YOU"
    Snail's Avatar
    Feb 2003
    San Jose, CA
    37
    15
    Negative on the factory harness. I pulled ALL the stock wiring since it was a premium system with eight speakers and three amps.
    So, no matter what is going on, the head will need it's yellow (power) wire hooked up to the positive side of the battery or something equivalent?
    Thanx guys.
    [email protected]
    Spddracer's Avatar
    Mar 2002
    Ohio
    50
    1,345
    15
    You are correct , It hooks up just like any other Stereo
    CDT HD 6.5" Comps
    JL 300/4 Active
    (2) PG Ti10d
    Directed 1100d
    "WORK HARD.....
    maylar's Avatar
    maylar is offline Electrical Weenie
    Jan 2002
    Connecticut
    66
    3,498
    2 Post(s)
    399 Post(s)
    The only difference between this install and any other is that the HU speaker wires won't go anywhere. All power, ground, remote, antenna, etc wires still have to be hooked up. That's basically what the guy was saying - you're only using the HU for it's preouts and remote functions. But it still needs power...
    dave
    1999 Buick Park Ave Ultra
    Head Unit: JVC KWHDR720
    EQ: Audiocontrol EQL
    Front Stage: Hybrid Audio Technologies Imagine 5.25 mids, Morel Maximo tweets
    Sub Stage: Boston G3 10", 0.5 cu ft sealed
    Amp: PPI Phantom 900.4
    Rear Fill: Boston SE953 6X9's
    Snail's Avatar
    Feb 2003
    San Jose, CA
    37
    15
    Totally answered my question(s). I appreciate the help.
    Thankyou!
    [email protected]
    Dreamworkz's Avatar
    Dreamworkz is offline Member
    Feb 2003
    Dreamwerkzinstallz
    33
    89
    All u do is get a dash kit and wire harness and match up everyhting the same and hook it all up identical.
    Dreamwerkzinstallz 03.
