Results 1 to 13 of 13
Reload Thread: noob amp question
    Radar's Avatar
    Radar is offline Old balls
    Feb 2003
    Earth
    2,052
    noob amp question
    Id like to hook up another sub into my car (totaling 3 subs, possibly 4 in the end) and I know how to hook up single amps fine, but I've never hooked up more than 1 amp in a single car. I need this second amp because im running 2 12's from 1 amp(very close to a full load on the amp) and id like to add another sub. How should I go about doing this. Both amps are 760W. Is it the same like a single amp, just run another power wire and ground?
    Thx
    bumpin_8605's Avatar
    bumpin_8605 is offline CarAudio.com Elite
    Jan 2003
    knoxville illinois
    31
    604
    ya except u might want to up grade ur alternator so ur lights wont dim and stuff like that
    PS u want that box built
    95 Camaro
    Clarion DXZ535
    Clarion EQS crossover
    Rockford 6.5" (1 set in back n another in doors)
    Rockford 301x for 6.5s
    Rockford 2-12" HE2
    Rockford 801s for subs
    aim- bumpin8605
    msn- [email protected]
    yahoo- chevyman4ever2003
    91 toyota celica for sale 2000
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,022
    1 Post(s)
    266 Post(s)
    If it were me I'd sell both amps on ebay and buy a class D amp that's capable of powering all 3 subs.
    But if you're set on using 2 760W amps (the sonys?) I would recommend getting a hold of a 4 ga dual amp kit off ebay, they're usually about $50 shipped. It will have all the stuff you need to wire two amps the right way.
    You'd run:
    • 4 ga wire from battery to fused distribution block
    • 8 ga wire from distribution block to each amp's (+)
    • 8 ga wire from each amp's (-) to un-fused distribution block
    • 4 ga wire from unfused block to grounding point
    • Remote wire can simply be daisy chained --> hu to amp to amp
    • RCA's - y-cables would be easiest
    • Also don't forget a fuse (about 60A) in your 4 ga power wire close to the battery (within a foot or 2)
    roester37's Avatar
    roester37 is offline Junior Member
    Feb 2003
    Maryland
    37
    15
    dual amp kit definetely the best setup
    Your asking for advice from me?
    Radar's Avatar
    Feb 2003
    Earth
    2,052
    one is pioneer, one is a sony amp. I think I might get rid of the other (sony) and get another pioneer.I thought about upgradin the alternator sence the lights are dimin' already
    PS I PM'd ya Bumpin
    Any recomended amp brands/models if i do go class D ? I know RF is good and a few others. Ill need an amp that can supply about 1400W max(400w to each RF 12 and 650W to a sony 10 i got sittin around) if i do go with 1 amp. how much wattige do yall think i actually need to power these subs well, all 1450W?
    n2audio's Avatar
    Dec 2001
    Lawrence, KS
    5,022
    1 Post(s)
    266 Post(s)
    Just a suggestion -- You should probably remove MAX ratings from your vocabulary when you're talking car audio. They are probably one of the most useless specs out there. It makes me kringe kinda like someone scraped thier fingernails on a chalkboard.
    What are the RMS numbers for your subs?
    Radar's Avatar
    Feb 2003
    Earth
    2,052
    Ill make a note of that...
    200 RMS each for the RF. the sony i think is 300 (i dont have the specs on it, its been in my garage for a while.
    Mr. Loki's Avatar
    Mr. Loki is offline Banned
    Sep 2002
    Missouri
    34
    5,856
    Well first of all its not a good idea to mix your subs. It doesnt help you...if you want to run 3 subs then get another rf 12. Also you wont need 1400watts of power. I would say a jbl bp 600.1 would do just fine.
  9. #9
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    yeah not good idea to mix subs. if you like the RFs get a third one, so you would only need a 600rms amp, which you can only get one easily.
    i would recommend looking at JBL 1200.1, also, another cheap alternative might be Profile, alot of ppl recommended this one cuz is a nice good amp n i was gonna get the CA-1200 one until i decided to go for another amp. But 600rms should be not bad. one question tho? what car do you have? cuz u said u running i'll think ~400rms for one amp n ur lights r dimming really bad? hmmmmm
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
  10. #10
    Radar's Avatar
    Feb 2003
    Earth
    2,052
    My car is a '94 lincoln continental. lights are dimmin somewhat, but only when system is cranked up. Part of the problem, i think, is that there are alot of things in the car that draws power, the speedomoter and all gauges are digital. a crapload of lights and lighted buttons. If i decide to get a jbl 600.1 should i run larger gauge wire? im runnin 8 now for power and ground. I could always go to 4. I know a Cap is not the solution to the dimming problem
  11. #11
    Mr. Loki's Avatar
    Sep 2002
    Missouri
    34
    5,856
    I have a lincoln continential also......lol mine is sittin on some 16 inch rims....lol my lights dont dim though....I have a 1000watt cold cranking amp battery with a 80amp alternator and my dash and everything is power also. You would be fine with the jbl bp600.1 8guage would be fine for the 600watt jbl, but any bigger you would need 4guage
  12. #12
    Matador's Avatar
    Oct 2002
    Ca
    2,093
    8 gauge should suffice for the 600.1.
    however, if you r planning to add another amp (for comps/speakerS) i would recommend you to get a 4 gauge now, n then just use a distro to iwth a 8 gauge power wire to connect another amp. just a suggestion tho
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    [email protected]
  13. #13
    Mr. Loki's Avatar
    Sep 2002
    Missouri
    34
    5,856
    Yea correct matador, I totally forgot to say that....if you get the 4guage now you wont have to take anything out to fix, but you will have to add stuff to fix...like a distroblock...so if you have another amp in your plans it wouldnt hurt to get 4guage now with a distro block. when the time comes you will be ready minus the 8guage wire.
