Results 1 to 2 of 2
Reload Thread: Can power wire be too large? And what will happen? Need scientific explanation
    audiocontr's Avatar
    audiocontr is offline Junior Member
    Feb 2003
    Northern Virginia
    41
    Icon32 Can power wire be too large? And what will happen? Need scientific explanation
    I'm looking to get into physics here an not just "Well you cant fit a one foot in diameter cable through the firewall".
    Does the diameter of the power wire ever become too large and detrement voltage? Does it plateau eventually?
    Where can i find information on the phenomena of energy moving along the edge of a wire strand and not the core? (thus the reasom why we use multistranded cable and not solid core)
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,022
    1 Post(s)
    266 Post(s)
    Re: Can power wire be too large? And what will happen? Need scientific explanation
    No. It's a simple matter of resistance. Any given length of wire, whether it be aluminum, copper, or solid silver, has a resistance value per length. The larger the wire, the less resistance.
    Yes. Once you have sufficient ga. you gain very little using larger wire. To the best of my knowledge the law of diminishing return applies to everything.
    I don't know a lot about that topic, but I belive the skin-effect applies more to ac than dc. I know I've read that solid core is technically the best for car audio (but not to a point of audible difference). We use stranded wire simply because it's flexible.
    If you really want info on it you might try www.carsound.com forums and search Richard Clark's forum and archives for Skin Effect. If you want more input on specific resistances of power wire and related info I'm sure you can find that there too. That forum tends to make my head spin when they get into science and engineering.
