Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
Reload Thread: testing amp with volt meter
    ActionJ-01-Z71's Avatar
    ActionJ-01-Z71 is offline Action Jackson
    Jan 2003
    TULSA
    42
    237
    14
    i know how to test the voltage. and every thing is fine there. but should i be able to getting any ohms if i touch the pos and neg terminals on the amp? (not sure if i am using the correct terminology)
    i would think no because if you did it would mean something internally is shorted.
    right?
    any comments woud be greatly appreciated.
    AJ
    Excelon x790
    Alpine Type S 6.5
    Alpine Type S 6x9
    Alpine Type R 12 4ohm DVC
    Kicker XS-100 @ 2 ohms
    BOOMER!!!!!
    Jan 2003
    TULSA
    42
    237
    14
    Re: testing amp with volt meter
    any body have any tips on how to test this dang thing? i have tried to test the speaker out puts and with my meter set at 15 volts and its not showing anything. ???
    Excelon x790
    Alpine Type S 6.5
    Alpine Type S 6x9
    BOOMER!!!!!
    Boulderguy's Avatar
    Boulderguy is offline Registered User
    Dec 2006
    Boulder, CO
    276
    What are you testing for?
    Jan 2003
    TULSA
    42
    237
    14
    any out put to the sub. just wondering if i can do that with a volt meter. i would think so just not sure since im not seeing any voltage coming from the amp at all.
    it was working yesterday...
    Excelon x790
    Alpine Type S 6.5
    Alpine Type S 6x9
    BOOMER!!!!!
    Boulderguy's Avatar
    Dec 2006
    Boulder, CO
    276
    Does the sub work? forget testing resistance (ohms), there's nothing usable there for you.
    Otherwise check HU volume, sub level volume, gains, source material, crossovers, etc.
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    33
    37,876
    is your dmm set to AC? just read the gain setting tutorial if all you are looking for is too see if signal is coming out of the speaker leads on the amp
    Jan 2003
    TULSA
    42
    237
    14
    Quote Originally Posted by Boulderguy View Post
    Does the sub work?
    it all worked yesterday.
    i have checked all levels and hu settings. reset the amp and hu. all i have left to do really is pull the hu to make sure rca's are connected well.
    Excelon x790
    Alpine Type S 6.5
    Alpine Type S 6x9
    BOOMER!!!!!
    Jan 2003
    TULSA
    42
    237
    14
    Quote Originally Posted by iceteebone View Post
    nope had it on dc.
    thanks
    Excelon x790
    Alpine Type S 6.5
    Alpine Type S 6x9
    BOOMER!!!!!
  9. #9
    joetama's Avatar
    joetama is offline The British Ear
    Nov 2005
    Cincinnati, Ohio
    32
    15,306
    Yea... I needs to be on A/C Voltage to read anything...
    And if you test the ohms over the + and - on the amp you should get a ohm reading but it will be rather high (btw this is with the subwoofer disconnected). If you get a really low reading or a dead short then your amp has a problem....
  10. #10
    BoomBoomBoy's Avatar
    BoomBoomBoy is offline Supreme Veined Member
    Nov 2006
    Everywhere, USA
    2,096
    As mentioned earlier, set the DMM to AC voltage. With your sub hooked to your amp, place the red lead on the + sub terminal, and the black lead to the - sub terminal. Play music at a moderate volume and you should see your DMM voltage read out jump up and down with the music. If it doesn't, there's something wrong.
  11. #11
    phyphoestilic's Avatar
    phyphoestilic is offline Liquid Fire...
    Jul 2006
    Riverside, CA
    30
    5,543
    Quote Originally Posted by BoomBoomBoy View Post
    uhhhh.... dont listen to him
    Just follow the gain setting tutorial, dont play music. Use a test tone so u can set the gain right. Also make sure ur + on the sub terminal isn't connected to the speaker wire.
    Lexus LS400 Setup
    Eclipse CD7000 (Running Active)
    Image Dynamic OEM CX64s
    Image Dynamics NX30 Tweeters
    US Acoustic USF600 x2, USF800 x2 (Zed Audio )
    150ft+ of Rammat
    IDMax12 1.5cft. I need to cut for IB
    25 feet 1/0 Stinger Expert, 15 feet 4 Stinger Pro
    Stinger Dream Series, Knu Konceptz Krystal Series RCAs
    Ref: (Bought From)Renegadesrun, IonSQL, CrazyJoker2, Alpine CDA-9815 , FI Car Audio, yournumber1dan , B_Campbell, jacobcopeland87, mike dressure x2, James_Bang, blue200sx
    (Traded w/) Iceteebone, sxkicker89
    (Sold To): James_Bang, timbo12, gsxrjjordan
    Ebay: PhyPhoestilic (100%)
  12. #12
    joetama's Avatar
    Nov 2005
    Cincinnati, Ohio
    32
    15,306
    Quote Originally Posted by phyphoestilic View Post
    I think he was just speaking in the terms of a quick and easy test to see if he is getting any voltage output not to set the gains....
  13. #13
    iceteebone's Avatar
    Aug 2003
    Michigan
    33
    37,876
    Quote Originally Posted by B&W_EE View Post
    x2
  14. #14
    Nov 2006
    Everywhere, USA
    2,096
    Don't listen to this!
    You are assuming he is trying to set the gains. Everything he's said leads me to believe he's troubleshooting.
  15. #15
    joetama's Avatar
    Nov 2005
    Cincinnati, Ohio
    32
    15,306
    Funny... I assumed he was trouble shooting too.......
